![]() | Home > General > Air compressor sound |
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 ![]() ![]() ![]() |
I get the same sort of noise out of my missus's Disco, but my RRS is silent and i lower the suspension every time i get out, therefore the compressor works every time i start it back up and drive off, i would get it into the dealers if i were you and get it checked out |
YY Member Since: 11 Jul 2006 Location: London Posts: 23 ![]() ![]() ![]() |
thanks envoy.. yes it also makes the same loud noise if i raise or lower the suspension.. it's annoying because it doesn't sound good, you can hear it from inside the car clearly and it's much louder outside.
hartleyhair Member Since: 08 Oct 2006 Location: Bournemouth Posts: 176 ![]() ![]() ![]() |
They don't all do that nor should they. And there was, I recall, a dealer requirement to check them all - this was over a year ago. This may be the upgrade to which you refer.
949BFN Member Since: 16 Apr 2007 Location: Bloemfontein Posts: 59 ![]() ![]() ![]() |
Would you believe it that the exact same thing happened to me two days ago. Had a flat and a friend did the jacking. 2010 Sport Supercharged with all options apart from TV and Extended leather (wish I had the latter) (Previously 2007 RRS S/C) |
