Home > Technical > Help with TSB # |
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 |
I don't think there is a technical bulletin for this. (Do you have "lazy entry" turned on?) |
Tue Jan 17 2006 11:10pm |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 |
I turned the auto dipping off - this solves the problem - but have found that the mirrors never find their true position again after my wife has been in the drivers seat & used the memory setting for her set position ( squashed up against the steering wheel ) then I get back in press memory 1 and sometimes I still have to adjust them manually. Hey ho..... a minor foible
Wed Jan 18 2006 12:15pm |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2579 |
Bish,
Wed Jan 18 2006 6:26pm |
Uh, *you* set the level of mirror dip by adjusting the positon while in reverse. You can then "save" the position to your memory settings. After going into Drive, it should return to normal "non-dip" mirror position.
Wed Jan 18 2006 7:22pm |
thebishman Member Since: 21 Dec 2005 Location: Kansas, USA Posts: 98 |
The problem is that after returning to the normal, non-dipped, position, the damn mirrors are invariably off from the 'set' position in Mem 1 by subtle, but appreciable amounts; such that I have to manually 'tweak' the positions at least 50% of the time. A PITA but nothing I can't live with I guess. I'll let the dealer know on Friday however.
Wed Jan 18 2006 8:14pm |
But did you try doing everything I said? "Lazy Entry" memory might be causing you grief. I guess if you have Lazy Entry off, it's not an issue... Do you have it on? |
Thu Jan 19 2006 1:12am |
Not sure about Lazy entry; I'll check. I'll also re-set all of the memory settings. I'll let you know what happens. Thanks for the advice, btw. Bish '06 RRS S/C Bonatti Grey/Ebony/Cherry with RSE; PTI; Electronic Rear Diff and Sirius Sat Radio. |
Thu Jan 19 2006 1:41am |
abrooker Member Since: 27 Nov 2005 Location: Clear Water Bay, Hong Kong Posts: 39 |
I have exactly the same problem. I reverse probably 5 times a day and definitely have to tweek the setting after a while. it always ends up a little bit too high and inwards. 2005 RRS SC 1st Edition Vesuvius Orange |
Thu Jan 19 2006 4:31am |
