Home > General > Basic Stereo Manuafacturer
Andrew R
Wales
Hi guys,
Has anyone any idea who manufactured the single CD unit for the RRS, obviously it's Harman Kardon for the others but the basic single CD unit is only branded Land Rover.
cheers
Andrew cheers
Andrew
RRS TDv6 SE, Bonatti Grey/Ebony/Rhodium
Post #10474 Mon Jan 16 2006 10:29am
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
When you say single CD unit do you mean the single slot 6 CD feeder?
If you do, this is made by Alpine. Harmon Kardon were used for the speakers.
For further information there is an article in LRO magazine issueDecember 2005, P208. L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #10477 Mon Jan 16 2006 10:49am
Andrew R
Wales
No I mean the single CD player, holds only one disc. Basically, when ordering the Europe Spec SE has this as standard and as I normally listen to the radio in the car I decided not to fork out for the Premium Stereo unit(H/K). However, bad advice from my dealer led me to believe that the AUX input was on all units ! On taking delivery I notice that this is not the case as I have no AUX input on the centre console rear. So basically I want to investigate how I can best integrate an ipod...........so whats the head unit manufacturer, does the aux button have something behind it etc etc......any information is welcomed.
cheers
Andrew cheers
Andrew
Post #10480 Mon Jan 16 2006 11:00am
RRUK
It will still be Alpine as they were involved in building the IHU, just a more basic version of the 6 disc player L319 D4 HSE
1982 Series 3 SWB
Post #10486 Mon Jan 16 2006 12:05pm
Andrew R
Wales
Thanks RRUK I will take a look around for some way of adding an AUX plug in the glove compartment with a remote control.
cheers
Andrew cheers
Andrew
Post #10492 Mon Jan 16 2006 12:15pm
It uses rubber bands! 2005 Zambezi TDV6 - Gone but not forgotten
Post #10493 Mon Jan 16 2006 12:15pm
grommet
United States
Wire to Pin 7 (left), Pin 8 (right) and Pin 12 (ground) of a connector labeled as C2115 behind the radio head unit. That's your AUX. Yes, you need to take stuff apart. Smile
Post #10553 Mon Jan 16 2006 5:31pm
byron
Greece 2006 Range Rover Sport Supercharged Bonatti Grey
Is it a certainty that Alpine is the sole manufacturer of the system installed in the RRS S/C as well? If so, how would you rate it, combined with the Harman/Kardon speakers? RRS S/C,Bonatti Grey,Ebony Interior,Lined Oak Finish, Rear Lock Dif, DVD,Sunroof,ACC
Post #10642 Tue Jan 17 2006 2:59pm
As far as I'm aware it's Alpine - and with the HK speakers sounds good (not fantastic though, if you are a hifi wiz). On the SC model you also get LOGIC7 thrown in which a lot of folks here have said is a disappointing implementation in the RRS. How well into your music reproduction are you?
Post #10643 Tue Jan 17 2006 3:24pm
byron
my other car has a linn system which sounds fantastic.As far as the RRS, I havent received it yet so I cant judge Confused RRS S/C,Bonatti Grey,Ebony Interior,Lined Oak Finish, Rear Lock Dif, DVD,Sunroof,ACC
Post #10646 Tue Jan 17 2006 4:24pm
