Home > Maintenance & Modifications > Autologic Dyno Results
stephenw
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Nara Bronze
All, I've just had the Autologic ECU remap done. I'm very happy with the results. On the drive home last night, about 300km, I just could not stop playing a bit. I'm glad the cops were not around. Smile
First impressions are that the engine/gearbox behaves in the same manor as before, it just has more power. Also, it may be my imagination but it seems to be a bit smoother under hard acceleration. It does hold higher gears longer.
Fuel economy, when not playing, seems to the same or a bit better. I did notice that when driving for economy, the average indicated consumption by the vehicle dropped quicker that I remember in the past. This would tend to indicate that it is getting better economy when treading lightly. However this is very subjective so I'll have to see in the long run. The trip from Sydney to Canberra last night (with a couple of v quick bursts) averaged 8.2 litres/100km. Normal cruise on this road is between 115km and 120km. My normal consumption is around the 8.0lt/100km. I can't complain about this.
Power increase at the wheels is about 20% This is shown in the following dyno report.
http://users.tpg.com.au/adslcuwf/File0001.pdf
Steve RRS TDV6 MY07 gone.
RRS TDV6 MY10 just arrived!
Post #102255 Fri Apr 13 2007 11:16pm
ivery819
Thanks Steve
Good solid factual information.
I would be interested to hear your thoughts as time/mileage goes on.
ps Has anyone done a conversion chart from road speed to engine revs in each gear ?
Here are the gear Ratios for the TdV6:
General Specification
Item Specification
Automatic transmission ZF 6HP26
Speeds 6 Forward, 1 Reverse
Gear ratios:
First 4.17:1
Second 2.340:1
Third 1.521:1
Fourth 1.143:1
Fifth 0.867:1
Sixth 0.691:1
Reverse 3.403:1
Torque converter Sachs W255 2GWK with turbine torsional damper and slip controlled, dual friction faced lock-up clutch
Transmission control module:
Location Located in gearbox casing
Type 1904
Post #102267 Sat Apr 14 2007 12:29am
stephenw
Peter, try these.
First one is a tyre size calculator. I used it for calculating the tyre diameter. It's also useful for looking at the changes that different sizes make to speedo etc. I'm not sure who the author was but it works very well.
http://users.tpg.com.au/adslcuwf/tyre.xls
The next one is a bit more complicated. It shows the kph vs RPM in each gear. I've just done a bit of a sanity check but if there are any experts out there that can point out any errors, I'd be happy to correct them.
http://users.tpg.com.au/adslcuwf/RRSSPEEDS.xls
Post #102269 Sat Apr 14 2007 2:04am
ivery819
Steve
They look pretty accurate.
For mine with 255/50/19 Contis 1930rpm is 100kph true in 6th.
(dash tacho says 1900 and speedo reads 104kph..........corrected with accurate gps and digital tacho.)
Have to crank up excel when I get time.
Am I correct in thinking that your graph covers the rev range of about 2500 to 4000 rpm.
If it does then that means the power increase is nearly constant over the rev range no engine/transmission destroying spikes or bumps....excellent!!! This is confirmed by your comments about smoothness.
btw Those are 2 very handy spreadsheets
Post #102270 Sat Apr 14 2007 3:08am
ivery819
For anyone else playing with this here are the differential ratios for each model
Rear 'Open' Differential
Item Specification
Reduction ratio:
V6 Diesel engine - Automatic transmission 3.54:1
V8 SC Petrol engine - Automatic transmission 3.54:1
V8 N/A Petrol engine - Automatic transmission 3.73:1
Rear Electronic Torque Managed (ETM) Differential
Item Specification
Electronic torque managed (ETM) range Up to 2500 Nm (98.5 lbf/ft)
Electronic torque managed (ETM) motor Operates the ball/ramp mechanism and wet clutch. Motor incorporates a temperature sensor and is controlled by an ECU
Differential type 4 pin
Reduction ratio:
V6 Diesel engine 3.54:1
V8 Supercharged Petrol engine 3.54:1
V8 N/A Petrol engine 3.73:1
Post #102272 Sat Apr 14 2007 4:30am
ivery819
stephenw
quote "I've just done a bit of a sanity check but..............." Shocked
I've checked and ....
you're just as mad as the rest of us Rolling Eyes
Post #102275 Sat Apr 14 2007 5:13am
stephenw
Yep, that's me....
 RRS TDV6 MY07 gone.
Post #102281 Sat Apr 14 2007 9:21am
ivery819
Laughing Rolling with laughter Thumbs Up
Post #102283 Sat Apr 14 2007 10:04am
LRtuning
2006 Range Rover Sport Supercharged Cairns Blue
Stephen,
The result you got seems at odds with autologics own performance figure results.
www.autologic-diagnos.com/news/tdv6.pdf
Anyone know of any reason why? Chips with everything
Post #102292 Sat Apr 14 2007 12:44pm
stephenw
I thought you may have known the difference between power and torque measured at the road wheels on a dyno compared to a flywheel measure, either on an engine dyno or calculated as such. RRS TDV6 MY07 gone.
Post #102307 Sat Apr 14 2007 2:15pm
LRtuning
Stephen,
I certainly do know but it seems to me that you have much greater losses than the dyno measurements I've seen in the UK.
It's just that I produced the original tuning files for Autologic last year and we were seeing at least another 15kw at the wheels than what you got?
What approximate losses did your dyno guy calculate or work from? Chips with everything
Post #102314 Sat Apr 14 2007 2:40pm
ivery819
Given all the variables...particularly fuel quality I would have thought 12.5% difference is OK Shocked
Post #102321 Sat Apr 14 2007 3:02pm
rrsjo
I thought 10% was more the norm, or is that just for two wheel drive and four wheel drive needs an allowance of 12.5% Question Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #102347 Sat Apr 14 2007 7:06pm
LRtuning
I just think this thread demonstrates the variations between dynos, operators and software Smile
And here's another dyno result from our 'friends' at Superchips
www.superchips.co.uk/curves/landrovertdv6.pdf Chips with everything
Post #102379 Sun Apr 15 2007 8:53am
GeorgeOrwell
Does anyone know if there is a perecentage formula for working out transmission losses or rolling road? "People simply disappeared, always during the night. Your name was removed from the registers, every record of everything you had ever done was wiped out, your one-time existence was denied and then forgotten. You were abolished, annihilated: vaporized was the usual word."
Post #105746 Sun Apr 29 2007 12:00pm
