Home > General > Programming the Land Rover Button on the Ignition Key
XUJG
Hi All
Has anyone successfully programmed the LR button on the key to opperate the susspension remotely?
I can make the LR button open the rear door or panic alarm but not the suspension.
Anyone had the same problem?
Thanks in advance
JG
Post #101598 Tue Apr 10 2007 9:07pm
Not possible unless the hazard lights are working. 2005 Zambezi TDV6 - Gone but not forgotten
Post #101600 Tue Apr 10 2007 9:08pm
XUJG
HI VA
Maybe I have misunderstood the manual then as I read it needed the hazzards to be activated but I read that to be setting the button up not needing to be on at the time.
What is the use of that then!?
Why would you want the Hazzards on to adjust the height.
Oh well just have it opperating the boot then.
Thanks again VA
Regards
JG
Post #101602 Tue Apr 10 2007 9:11pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Remote suspensions raising/lowering is a useful feature if you have a trailer to hook up to the Sport on your own. Being able to raise or lower the car remotely makes it easier to line up the trailer hitch with the receiver. Otherwise, it's a pretty useless feature (due to the hazzards requirement, that is.)
Post #101604 Tue Apr 10 2007 9:16pm
XUJG
Thanks umbertob
Not having a trailer I couldnt see a use but now you have explained I see the possibility and you would probably have the hazzards on at the time.
I was hoping it would be usefull for raising suspension after parking to avoid the door knocks as it has been posted here that raising the suspension helps protect if you have steps to catch the offenders door.
Of course I would put a soft protector on the step so as not to damage the other car!!
Regards
JG
Post #101607 Tue Apr 10 2007 9:28pm
umbertob
When I first bought the car I couldn't wait to enable that feature so that my friends could go "Oooh!" and "Aaah!" from a distance. Bummer!
Post #101609 Tue Apr 10 2007 9:33pm
I was hoping for the same Laughing Laughing
Post #101611 Tue Apr 10 2007 10:17pm
Frisco_TX_RRS
United States 2006 Range Rover Sport 4.4 V8 HSE Java Black
Would be nice to have a combination of -
Lower Vehicle & Lights On & Un-Lock.
Side note - Is there any way to have the lights turn on when the vehicle is un-locked via the remote?
Post #102647 Mon Apr 16 2007 4:50pm
umbertob
Not automatically. My old Volvo S80 used to light up that way when unlocked. I think I replaced H7 halogen bulbs on the headlights of that POS at least a dozen times in 4 years of ownership, though. Don't know if that was related.
Post #102658 Mon Apr 16 2007 6:02pm
Frisco_TX_RRS
[quote="umbertob"]
Don't think so - had another car with HID that did it for 5 years before the bulbs needed changing.
I feel it's a nice feature to have - hopefully a hack comes out for it soon.
Feel its pretty useless to have only 1 feature programmed - would have just settled for having the car lowered from the remote.
Post #102659 Mon Apr 16 2007 6:22pm
