Home > Technical > Intermittent Wipe
Rob_J
Location: Usually flat out on the sofa with glass of vino
England 2005 Range Rover Sport TDV6 HSE Java Black
Intermittent Wipe
Now this could be just me but this seems to be absolutely useless, I've played around with the thing & no matter what I do seems to make no difference whatsoever to the wipe speed. The intermittent seems to be just too quick. Anyone else notice this or is this a little gremlin? HSE TD6 (Java Black/Ivory)
911GT3 (Guards Red, carbon interior)
ElanSE (BRG)
Panamera Turbo S
Boxster S
Post #10034 Wed Jan 11 2006 10:26am
I see what you mean, I too have thought it useless. But then we have auto rain sensor which is telling the wipers to wipe, so how can the intermittent cope with this as well ?
Use RAINEX and switch the bl**dy things off altogether Wink
Post #10039 Wed Jan 11 2006 10:41am
This happens with me too, but I think there's a general issue with the intermittent wipe. I remember the RRS I test drove before buying mine also had the same problem as it was pouring then and I couldn't find the speed I wanted. Typically, the wife's Freelander intermittent wipe works perfectly.... Rolling Eyes
Post #10074 Wed Jan 11 2006 1:49pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
The auto sensor is ok, but like everyone says, there appears to be no change in sensitivity and therefore frequency of wipes when you alter the stalk dial.
They need to look into this. I am guessing it's not a fault but a design or part problem that is across all models. L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #10077 Wed Jan 11 2006 1:51pm
d3matt
United Kingdom 2005 Range Rover Sport TDV6 SE Bonatti Grey
There has been other posts on this and the wiper configuration has been a big issue to me.
Anyway, for those who have automatic wipers (all models except 'S'), you do NOT have an intermittent option on your wipers. When you select the first position (this would be the intermittent normally) you are actually selecting the automatic rain sensor. The wipers then do it themselves.
The rotary dial then changes the delay of the rear wiper. Ignore what the manual says. It is wrong. The rotary dial changes the delay of the rear wiper only and does not adjust the sensitivity of the auto wiper sensor.
While on the subject of wipers again.....if your wipers are noisy - check the wiper blades - the rubber tears and they need replacing. They don't last long. Mine only lasted a few months. Matt
RRS ownership for 1 yr, then D3 for 2 yrs. Then cut back to old bangers and working my way back up through two Peugeots in 6 months. Now got Saab 9-5 2.3t and enjoying the performance!
Post #10167 Wed Jan 11 2006 8:47pm
Rob_J
Thanks Matt that solves it, still hopless but at least I know why!! I'll do my own intermittent from now on! HSE TD6 (Java Black/Ivory)
ElanSE (BRG)
Panamera Turbo S
Boxster S
Post #10169 Wed Jan 11 2006 9:39pm
RRUK
Well Censored Me! I thought I had read the manual well enough. Now I know why I have been leaving the rear wiper off most of the time, cos I felt it was wiping too frequently, and that's cos I was getting it all wrong...
I prefered the system in the BMW's, where you can adjust the sensitivity of the rain sensor though. L319 D4 HSE
1982 Series 3 SWB
Post #10171 Wed Jan 11 2006 11:22pm
Rob_J
I prefer the system in the Porsche an infinitely variable intermittent wipe, seem to be anything from 30 sec between wipes to virtually normal operation. What the hell do you need rain sensors for anyhow? You mean drivers can really not tell when to remove the rain from the windscreen Rolling Eyes HSE TD6 (Java Black/Ivory)
ElanSE (BRG)
Panamera Turbo S
Boxster S
Post #10174 Thu Jan 12 2006 12:33am
RRUK
All,
This puzzled me enough for me to go to great lengths to cut and paste the sections from the owner's manual as below.
If you read the section for the front wipers in the box below, it clearly states that the intermittent delay can be altered via the dial on the stalk. If you look AT the stalk, the pictogram for the delay dial is one of the windscreen (curved screen picture) and not the rear window (rectangular screen picture)
However, it THEN says on the following page the the delay can be altered for the the rear also! (See second picture)
Interesting to note you can have the dealer tweak the rear wiper for continuous operation.
 L319 D4 HSE
1982 Series 3 SWB
Post #10337 Fri Jan 13 2006 6:14pm
I've never used such a counter-intuitive system for wiping your screens. I do wish car manufacturers would all stick to the same rules. Mad
Post #10348 Fri Jan 13 2006 6:39pm
d3matt
This has been dicussed before, see http://www.rrsport.co.uk/forum/viewtopic.p...mp;start=0
I too extracted the relevant pages from the manual to prove the same point that the manual is wrong.....or maybe the car is wrong! Matt
Post #10362 Fri Jan 13 2006 9:50pm
ST
Well it works as designed on the D3!
If you have the front wipers switched to rain sensor, each time you move the sensitivity up on the stalk you get an extra wipe - tried it several times when I first bought it. If you then pull the rear on it does sensitivity for the front and intermitant for the rear!!
Most recent cars I have owned have had sensor wipers and I think this is the best version I have seen yet.......LR, don't ya just love the consistant approach to the build Laughing
Will look out for this when the new addition to the family hits the drive Currently: Carbon Black 535d
RIP: RRSTDV6 HSE & DISCO3 HSE
Post #14539 Sat Feb 25 2006 6:15am
w55ksy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
My 2009 RRS auto wiper drives me mad! I've had BMWs since 2000 and they sussed this problem out perfectly years ago. Whenever there's rain - the wipers work just the right amount.
The version on my RRS waits until just about the point where there's so much drizzle on the screen you are nearly forced to use manual mode - then you get a measly wipe and wait for the screen to build up to the point you can barely see again!
Please don't mention the sensitivity bit on the stalk - I am convinced it's just there for show!
Has anyone had a dealer increase the sensitivity of the auto wiper such that they work as well as BMWs did 15 years ago?
Post #482064 Wed Dec 09 2015 9:23pm
The Penguin
Glad it's not just me! 2012 RRS and has the same issue! 2012 Satorini Black SDV6 HSE
1999 S1 Lotus Elise Honda
Post #489649 Tue Mar 01 2016 10:04pm
On my 2005 the rain sensor does the front
and the adjuster alters the delay on the rear wiper.
Post #489725 Wed Mar 02 2016 1:24pm
