Home > Faults & Fixes > bouncing revs issue **SOLVED**
what do you think the issue is?
MAP sensor
0%
 0%  [0]
Torque convertor
80%
 80%  [4]
EGR
20%
 20%  [1]
something else
0%
 0%  [0]
Total Votes: 5
jpvd
Will give it a go...
Already had a new oil pan, filter and oil a few months ago...its after that the troubles started...had to do it since the old pan was leaking, otherwise wouldn't have touched it 🙈🙈🙈😆
Post #636614 Mon Oct 16 2023 1:03am
jpvd
Finally fixed my issue (all good so far anyway! - so fingers crossed)
I had my garage do a full flush of the transmission, add two tubes of dr tranny and new oil. Also had them change the diffs and transfer box oils too. It now runs like a dream - butter smooth gear changes, no bouncing of rpm, like new...
Made a massive difference 👍
Next job is a remap for more power and torque, but that can wait for now - spent enough this side of xmas 🙈😂🤦🤦
Post #637070 Sat Nov 04 2023 6:50pm
John R Hickman
England 2009 Range Rover Sport TDV6 S Santorini Black
Good to hear it's sorted your issues out. I.ve just had a remap and EGR delete done by Superchips and I'm really pleased with it. Really notice the difference from around 1800rpm and the suicide pause when pulling off has gone (Probably EGR delete did that bit). I wasn't really interested in the remap but as it was on offer for £325 all in I had it and I'm happy I did because the real difference is phenomenal when towing the tin tent around, the extra torque has totally transformed it as tow car. 2008 RRS 2.7 TDV6 S Poverty model
Post #637075 Sat Nov 04 2023 10:00pm
Dr Tranny isn't a forever fix, so you probably want to put some money aside for the day it starts again
Post #637156 Wed Nov 08 2023 8:08pm
jpvd
I think it was a mixture of dr tranny and the proper flush. Before the pan and filter was swapped it was running ok, no bouncing. Then after the swap it started playing up, probably because the oil wasn't flushed out and only drained and topped off. The flush got rid of all the old oil
Finger crossed it lasts a good while now. I only do around 6-7k a year so if it lasts another 30k it will see me through for a few years...🤟👍🙈🤞🤞
Post #637160 Wed Nov 08 2023 11:34pm
jpvd
Thats good to hear...its amazing how much power it unlocks. My egr is already bypassed, but the ecu still thinks its there, so having the full remap and egr moved from ecu. Been quoted £200, on my doorstep, which I don't think is a bad deal for all that extra power 👍
Post #637161 Wed Nov 08 2023 11:36pm
