Home > Maintenance & Modifications > Premium diesel recommendations ?? |
dazza2802 Member Since: 05 Mar 2021 Location: Liverpool Posts: 26 |
Having not had my,2011 RRS 3.0 tdv6 hse (89,000 miles), long, I will be running it on premium diesel for a while and was wondering if anyone had a preference in brands. I know some of you will think premium fuels are a conspiracy and a waste of time... if it is, I’m using it as a mental feel good feeling... like after you wash the car it seems to run better lol ( am I the only one lol).
Thu Apr 01 2021 2:58pm |
Cheers. Don’t really know what I’m expecting to get out of it really, but will be filling up with V power tomorrow |
Thu Apr 01 2021 6:58pm |
Gjlatz Member Since: 01 Mar 2019 Location: UK Posts: 40 |
Hello all, I did a couple of experiments over the winter with diesel fuel. I started the RR on a cold morning without pre heating the engine with the FBH, using Jet diesel for a while and the initial idle was really quite uneven. The same Jet diesel with a pre heat from the FBH as I always do and the initial idle was nice and smooth. After a couple of week using V Power diesel and a cold start wit V Power and no pre heat from the FBH the initial idle was smooth. I know it’s not very scientific but it was a real world test. We’re using V Power constantly now. |
Fri Apr 02 2021 1:43pm |
The problem with more “scientific” is that it’s not real world so I think your findings are far more useful. Thanks for that |
Fri Apr 02 2021 5:14pm |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 465 |
I use BP Ultimate Diesel so must be the odd one out,
Fri Apr 02 2021 7:10pm |
Phileep Member Since: 04 Feb 2019 Location: LEIGH-ON-SEA Posts: 49 |
Hi RRS's. +1 for premium Diesel. Not sure if it makes any difference but just feel good every time i fill her up |
Fri Apr 02 2021 8:35pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
The point about scientific is that it is repeatable and verifiable. "Real world" gut feeling results aren't. That's why scientific makes things like cars, aircraft, spacecraft, vaccines, computers. And the other way leads to astrology and crystals... Now, if you were to approach the comparison using double blind tests, we might be able to make a valid conclusion. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Apr 02 2021 11:44pm |
Yes, of course, your right. Thing is my gut is so large that my gut feeling has to be right lol... joking aside, you can’t beat scientific tests and results. I think most folk, including myself, put Prem juice in their tanks because of the “feel good” factor with the added hope it will indeed do something worthwhile |
Sat Apr 03 2021 7:53am |
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 237 |
The science shows V-Power petrol gives added bhp/performance especially on a turbocharged engine.
Sat Apr 03 2021 9:46am |
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 |
I've used bog standard supermarket diesel albeit with millers eco max in since I bought the car 70k miles and near 6 years ago. No issues. Drives fine. |
Tue Apr 06 2021 2:28pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
I just use regular shell diesel. Its on my work commute but have never put the posh diesel in and it’s a 2.7 so slow enough. I get 28 mpg and good emissions at the MOT. 2006 2.7 TDV6 HSE in Cairns Blue. |
Tue Apr 06 2021 3:08pm |
I'm still of the opinion that the fuel used is less of an issue than how you drive the vehicle. Short runs, never getting it properly warm, or long periods sat idling in heavy traffic, are not going to be great for the engine or emissions kit. Driving it for 30 minutes on the open road will ensure everything gets up to temperature, that the emissions devices are able to self-clean, etc., more than the additives in the fuel will.
Tue Apr 06 2021 3:23pm |
MartinsTDV8 Member Since: 22 Feb 2017 Location: County of Sutherland. Posts: 140 |
Driving style is for me the biggest issue. I always use supermarket fuel with REDEX added, in my TDV8, and did likewise in my D3 TDV6.
Tue Apr 06 2021 5:18pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 869 |
I use supermarket fuel. but after reading a rather long article on here a year or two ago, I add a 300ml of semi-synthetic 2 stroke to a tank of fuel. No problems, supposed to lube the injector rail. Don't know if its any better than Snake oil, but I'm happy with it Car is fast as |
Tue Apr 06 2021 6:33pm |
