Home > Maintenance & Modifications > Hissing noise from suspension accumulator |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4793 |
no air addition point.
Mon May 13 2019 6:15pm |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
Good news all round then, Andy! |
Mon May 13 2019 7:04pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
Are you sure it is from the accumulator (air tank) because if it was it would be leaking all the time as it has no "on/off" valves as that is done by the central valve block. If you had a leak the air compressor would not be able to achieve the required pressure in the tank and you would get a fault.
Tue May 14 2019 1:17am |
Hi Gary,
Wed May 15 2019 12:42pm |
No hissing.
Wed May 15 2019 4:09pm |
Sod it - off to the byways of the Lake District I shall go... |
Thu May 16 2019 8:19am |
