Home > Technical > RRS oil level |
Are you following the correct procedure 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sun Dec 09 2018 5:14pm |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 465 |
Try This one..
Sun Dec 09 2018 5:24pm |
blueiceplus Member Since: 21 Feb 2014 Location: wigan Posts: 66 |
Ok thanks I'll try that. |
Sun Dec 09 2018 7:13pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
Make sure you are not resting your foot on the throttle pedal slightly either or try putting your toe under it and lift the pedal very slightly when checking.
Sun Dec 09 2018 9:16pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
Should be in the owners manual Visitor from fullfatrr.com
Sun Dec 09 2018 10:19pm |
