Home > Maintenance & Modifications > 2010 HSE rotational noise
Oldandconfused
2010 HSE 3.0 V6, 63k, has developed a rotational rumble from the rear.
-only does it when warm, 5+ miles or so
-forward and reverse
-EPB replaced 6 months ago, working correctly, no binding (rolls easily on neutral)
-only audible at walking pace to about 10mph
-doesn't increase to a hum when going faster
-no clunks
-when raised to off road height, it becomes inaudible.
My initial thoughts were binding EPB, but not apparently binding plus was adjusted on the new EPB being fitted. Maybe wheel bearing but it passed it's MOT in August and I thought they became louder the faster you go. Prop shaft centre bearing was another thought, but they are supposed to clunk aren't they? Possible knackered UJ on the prop?
It's booked in next week, but any ideas gratefully received.
Post #569185 Sun Nov 18 2018 5:05pm
Tyrefitter
It could be a feathered tyre,,ive had this problem loads of times,,sounds like a bearing but it’s a tyre,,rub your hand around the edge or the inside of the tyre & if it’s feathered you will feel a up down motion on the tread.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #569186 Sun Nov 18 2018 5:37pm
Tyrefitter
A few pics I’ve found on internet
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #569187 Sun Nov 18 2018 5:41pm
Oldandconfused
Cheers Andy, I usually give the tyres a visual check at least every week (they get a cursory check each time before I leave home, don't want to drive on a flat and ruin it), but I will get out tomorrow and give them a good look over.
I should perhaps have mentioned that it's not a constant rumble, more cyclical every revolution or so, if it had been a click/tapping noise I would have thought it was a stone in the tread. The wheels are balanced and there is no vibration as I would expect with a miss-balance.
Post #569196 Sun Nov 18 2018 7:32pm
Tim in Scotland
A wheel bearing on the way out? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #569201 Sun Nov 18 2018 11:03pm
Oldandconfused
That is one possibility that I had considered Tim. That it was MOT'd 4 months and probably only a couple of thousand miles ago, and it not getting louder with an increase in speed makes me less certain. I have had a front wheel bearing go on my D3, which made no noise at all, so I appreciate noise isn't definitive.
I'm sure the indi I use will have a failed wheel bearing in mind when he gets it on the lift, but I welcome any experience/suggestions.
Post #569202 Sun Nov 18 2018 11:31pm
Tim in Scotland
Have you driven any gravel tracks or through and mud/stones mixture recently? Sometimes small stones get suck in disc guards on my Defender and can make a similar noise which turns into a squeal until the stone has worn away enough to drop out. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #569204 Mon Nov 19 2018 12:48am
Oldandconfused
Good god man are you insane, might get it dirty Embarassed It's my 4th Land Rover and they all had an easy life.
Thanks for the thought though
Post #569211 Mon Nov 19 2018 9:02am
Tim in Scotland
Ahhhh a car park queen then Wink 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #569221 Mon Nov 19 2018 11:41am
