Home > Maintenance & Modifications > 2010 HSE rotational noise |
It could be a feathered tyre,,ive had this problem loads of times,,sounds like a bearing but it’s a tyre,,rub your hand around the edge or the inside of the tyre & if it’s feathered you will feel a up down motion on the tread.
Sun Nov 18 2018 5:37pm |
A few pics I’ve found on internet
Sun Nov 18 2018 5:41pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 748 |
Cheers Andy, I usually give the tyres a visual check at least every week (they get a cursory check each time before I leave home, don't want to drive on a flat and ruin it), but I will get out tomorrow and give them a good look over.
Sun Nov 18 2018 7:32pm |
A wheel bearing on the way out? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Nov 18 2018 11:03pm |
That is one possibility that I had considered Tim. That it was MOT'd 4 months and probably only a couple of thousand miles ago, and it not getting louder with an increase in speed makes me less certain. I have had a front wheel bearing go on my D3, which made no noise at all, so I appreciate noise isn't definitive.
Sun Nov 18 2018 11:31pm |
Have you driven any gravel tracks or through and mud/stones mixture recently? Sometimes small stones get suck in disc guards on my Defender and can make a similar noise which turns into a squeal until the stone has worn away enough to drop out. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Nov 19 2018 12:48am |
Good god man are you insane, might get it dirty It's my 4th Land Rover and they all had an easy life.
Mon Nov 19 2018 9:02am |
Ahhhh a car park queen then 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Nov 19 2018 11:41am |
