Home > General > temperature goes up range rover sport 2014 model |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 |
Probably just airlock Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Sun Sep 16 2018 7:03pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 747 |
Did you bleed the cooling system? If you didn't, there are probably air-locks in there preventing the coolant circulating and causing overheating. I don't know the bleeding procedure for your car, try a google search, or someone on here may be along shortly. |
Sun Sep 16 2018 7:05pm |
alsayyed Member Since: 07 Apr 2018 Location: qatar Posts: 8 |
yes we did the bleeding , it looks ok know but why acted so badly in the begining |
Sun Sep 16 2018 7:15pm |
Ian.H Member Since: 04 Oct 2014 Location: England Posts: 180 |
A common "trick" when refilling the cooling system is to also have the heater on blowing out hot air as this tends to open up any of the gates in the system. Sometimes it can eleviate the need to actually bleed a system.
Sun Sep 16 2018 7:47pm |
