Home > General > temperature goes up range rover sport 2014 model
alsayyed
Qatar
Hello friends lately I have changed the water pump on range rover supercharge sport 2014. After changing the water pump I have poured the premix solution coolent 50/50 into the radiator, after 10 minutes the engine got so much hot, I have switched the car off and drained some of the solution and then added some water then started the car and drove for 60 kilo meter of distance and the temperature now in the middle , I do not know what happened in the begging, dose anybody run into this situation before.
Thank you
ahm
Post #565276 Sun Sep 16 2018 6:56pm
hoppy_70
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Probably just airlock Range Rover Sport 3.0 SDV6 HSE Dynamic 2016 MY
Range Rover sport 3.6tdv8HSE 2007 Gone
Range Rover sport 2.7tdv6SE 2005 Gone
Range Rover sport 2.7tdv6SE 2007 honey
Range rover Vogue 2005 4.4 - GONE and missed
BMW 535d M sport 2006 - GONE not as missed
BMW X5 4.4 2004 sport - GONE
Post #565278 Sun Sep 16 2018 7:03pm
Oldandconfused
Did you bleed the cooling system? If you didn't, there are probably air-locks in there preventing the coolant circulating and causing overheating. I don't know the bleeding procedure for your car, try a google search, or someone on here may be along shortly.
Post #565280 Sun Sep 16 2018 7:05pm
alsayyed
Qatar
yes we did the bleeding , it looks ok know but why acted so badly in the begining
Post #565282 Sun Sep 16 2018 7:15pm
Ian.H
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
A common "trick" when refilling the cooling system is to also have the heater on blowing out hot air as this tends to open up any of the gates in the system. Sometimes it can eleviate the need to actually bleed a system.
Just for future reference in case this wasn't done Smile
Cheers..
Ian
Post #565285 Sun Sep 16 2018 7:47pm
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
