Home > Faults & Fixes > Black smoke underload |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
First of all, any fault codes? |
Sat Sep 01 2018 2:34pm |
Rodgerwcostello Member Since: 01 Sep 2018 Location: Scotland Posts: 8 |
I have had smooth running error/fault that is the only one. Not a thing else |
Sat Sep 01 2018 2:51pm |
Black smoke is top much fuel or not enough air. A smooth running fault would possibly point towards an over fuelling injector, boost leak, turbo issue, or lack of compression... |
Sat Sep 01 2018 4:09pm |
I'm tempted to go down the overfuelling or faulty injector also as everything else was checked by lr , turbos eyes etc.
Sat Sep 01 2018 4:53pm |
I am unsure if an injector clean is something to do prior to paying out hundreds for a new injector and labour tbh |
Sat Sep 01 2018 5:10pm |
I'd suggest money would be better spent on a decent couple hours diagnostic work than an injector clean... |
Sat Sep 01 2018 5:44pm |
Yeh I think your right too as pointless guessing on each thing. I actually think before I changed the egrs it was smoking , the lumpiness has just started since they were fitted, so either the eyes are faulty which have been tested as ok, then some connection isn't right somewhere , thanks also ill get it booked in and wait for the end bill lol |
Sat Sep 01 2018 7:44pm |
It would appear its the os inlet manifold.
Wed Sep 05 2018 11:37am |
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 |
A well known fault. But are you sure it is just the inlet manifold ? Did you also get codes read ?
Thu Sep 06 2018 7:41am |
Well they said couldnt do a diagnosis or the computer said this cause this was leaking, i dont have any warnings at all on the car.
Thu Sep 06 2018 9:06am |
The only thing that happened was the intercooler hoses burst and then limp mode.
Thu Sep 06 2018 11:09am |
