Home > Maintenance & Modifications > National Windscreens |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
I had mine done last October which was replaced on the driveway. After the work was done I found broken glass on the back seat! which I can only assume came from a sheet over the seats. Anyway very quickly I got the passenger footwell leak fault which was a direct result of the disturbance of the scuttle panel (which obviously has to be done). I put in a complaint and a bloke from a different branch came to investigate. The screen was fitted well but some of the A pillar trim clips were missing and he filled the top holes with PRC/RTV and said it should have been done and will file a report. I received a financial compensation and the refund of the cost for a new cabin filter, as that was the entry root for the water.
Fri Aug 24 2018 7:04am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
Removed. Wrong company. |
Fri Aug 24 2018 9:20am |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
It is illegal for an insurance company to force you to use a specific repairer, certainly for body repairs. They can remove benefits such as a courtesy car if you decide to choose your own repairer, but they cant stop you choosing who works on your car and are obliged to pay up regardless of who you instruct.
Fri Aug 24 2018 5:33pm |
Thanks for the replies, i will make a few more enquiries and let you know how i get on 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sun Aug 26 2018 10:05pm |
