Home > General (L494) > Memory Seats Height Issue |
Do you press M then the memory number until you hear the gong and get a message in the dash screen? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Jul 09 2018 2:25pm |
00by Member Since: 25 May 2018 Location: Northants Posts: 81 |
Yes, it confirms it with the sound and dash message. MY16 RRS 3.0 SDV6 HSE Dynamic |
Mon Jul 09 2018 2:28pm |
Could it that you don’t use the same key fob every time then? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Jul 09 2018 2:30pm |
Nope - I only ever use the one fob.
Mon Jul 09 2018 2:34pm |
Sounds like a trip to the dealers then...... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Jul 09 2018 2:58pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1936 |
My seat doesn’t move when I stop the car, neither does the steering wheel. |
Mon Jul 09 2018 3:11pm |
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 |
Have you tried turning off the auto mode for the steering wheel? That should stop the wheel and seat moving when you stop the car but you may still have a problem with the memory function.
Mon Jul 09 2018 8:50pm |
Chips Member Since: 09 Nov 2017 Location: Shropshire Posts: 101 |
Not the same problem butI find quite often that if I only press the memory function once , it adjusts a little bit but no where near to where it should and doesn't move the wheel at all , however if I press it again and hold on the button it will go to the correct position . Just a landrover quirck |
Mon Jul 09 2018 9:00pm |
ianmo Member Since: 08 Jan 2017 Location: Southampton Posts: 119 |
I had the same problem with my 17MY, dealer sorted it under warranty, but I think it's started again! |
Mon Jul 09 2018 10:43pm |
Thanks for the tip on the steering wheel - it's a shame you can't change it so just the wheel moves and not the seat!
Tue Jul 10 2018 10:56am |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 411 |
In the olden days, the pedals were adjustable and used to move out the way too.
Tue Jul 10 2018 1:35pm |
Sorry no idea, it worked when it came out, that's all I know! |
Tue Jul 10 2018 10:48pm |
