Home > Technical > Another issue. |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
I posted a reply to this on another thread as I too have the squeaking suspension. I had it checked by my indi and they said front ARB bushes with surface rust caught up in them. The bushes are fine and don't need replacing but in this very hot weather will squeak and creak.
Thu Jun 28 2018 11:58am |
Really? Steve. |
Thu Jun 28 2018 11:59am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
Use a small spray bottle and spray a soapy water mix on to one bush at a time (match left to right) and after a few minutes to soak in, take it for a drive. Does it rattle rather than squeak? Is it only while straight or mainly when cornering? 2012 5.0 SC AB
Thu Jun 28 2018 1:12pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
Rear hub bushes. 2012 SDV6 - it's missing a couple of cylinders
Fri Jun 29 2018 12:31am |
WD 40 on the ARB bushes sorted mine - see the second part of this post:
Fri Jun 29 2018 8:03am |
It`s more of a creak and it does it as I`m driving along...constantly. Steve. |
Fri Jun 29 2018 10:20am |
Pretty sure it`s coming from the front. Steve. |
It`s going into the garage next week to have my suspension issue looked at so I`ll get him to do the WD while it`s there Steve. |
Fri Jun 29 2018 10:21am |
I’d be tempted to put money on it thst it’s the ARB bushes. My squeaking was just the same whilst moving along. The slightest bump would set them off. I reckon that the WD will fix it. Or a good rain storm😀. But not much chance of that for you with Porthmadog being the warmest place in the UK☀️ Robin
Fri Jun 29 2018 10:27am |
Yeah no chance of a downpour for quite a while.......reminds me of the Summers I had as a kid Steve. |
Fri Jun 29 2018 10:29am |
I thought you had to be careful with WD40 as it can eventually break the rubber down. 2012 5.0 SC AB
Fri Jun 29 2018 11:49am |
I wouldn't use oil or WD 40 on the bushes. Get a silicon based lubricant, Halfords do one, that will not harm the rubber. |
Fri Jun 29 2018 12:53pm |
Thanks for the advice and the tip on WD guys
Fri Jun 29 2018 4:19pm |
Just been shopping and there wasn't a peep from underneath...not a sound, drove lovely....coming home, about quarter mile away and it started again....sooo annoying. Sounded like the rear this time, god knows. Sounded like a bag of . I'll get some silicone spray and see if that sorts it as suggested. Steve. |
Fri Jun 29 2018 8:38pm |
