![]() | Home > Technical > Noise on Full Lock |
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1563
OK, so my TDV8 has been well behaved for a while. However, cos its hot, I had the windows open and noticed this sound on full lock as I pulled into my drive. Its not a particularly high kerb or anything - just a normal drop kerb to cross the pavement.
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
It happens at the point the wheel goes up the drop Kurb so to me it must be related to the front right suspension bushes or damper unit. I’d be tempted (never done this though) to squirt soapy water on to one bush at a time and repeating the same turn onto your drive to see if the noise changes. If it does, you’ve found the issue. 2019 5.0 SC SVA (Current)
Cheers guys. Thanks for the thoughts.
Got it to my indie at Heathfield yesterday afternoon and immediately Leigh knew what if was. He's even checked out my You Tube recording as well - how's that for preparation. So the clanking sound was cured with a dollop of grease each side on the lower front suspension arm. On full lock it can foul but nothing serious. My offside arm is a pattern arm and Leigh suggested that it may be slightly out as regards measurement ( the nearside one is LR). Grease goes here:
| Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784
My bad, when I said bump stops, I actually meant steering stops |
Haha - no problem.
| All times are GMT |
