Home > Technical > RRS 2007 v8 diesel. |
raysheppard1954 Member Since: 21 Sep 2017 Location: birmingham Posts: 10 |
hi ,i have a strange noise coming from the dash or centre console when i turn the steering wheel to the left ,more so when i turn full left ,only when the car is moving.it sounds like a relay or a rattling sound,i looked all round in the cab and been underneath.it gets louder the more you turn the steering wheel to the left nothing happen to the right .no lights or errors coming on.any help with this problem would be good.thanks ray. |
Thu May 31 2018 10:34am |
d-9 Member Since: 10 Jan 2017 Location: Herefordshire Posts: 299 |
Cornering lamps are separate to the adaptive lights that move the headlamp beam, the cornering lamps are the ones that illuminate at a certain steering angle/speed, or when you put the indicator on at low speed.
Thu May 31 2018 10:54pm |
hi ,thanks for your replies ,i have replaced the n\s headlight with a second hand unit from ebay a few months ago so it might be that.the noise sound like a relay clicking or some thing rolling under the dash.i will unplug the head light too see if its still there,thanks again.ray. |
Fri Jun 01 2018 6:28am |
