Home > Faults & Fixes > P2098 and Hose info |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
Isn't that the battery vent pipe? It vents the hydrogen produced during charging away from the battery/fuse box etc. 2012 SDV6 - it's missing a couple of cylinders
Thu May 17 2018 8:10pm |
austinsec Member Since: 17 May 2018 Location: Roslyn Posts: 4 |
Ok what do you recommend I do for the P2098 code |
Fri May 18 2018 5:11am |
Check around the throttle body/rear of plenum chamber for any loose pipes, not sure about the 4.4, but on the 4.2 there is an air pressure sensor that can blow off with age.
Fri May 18 2018 12:24pm |
Ok, I have a 2007 RRS HSE , Throws code P2098 lean trim post cat bank 2.
Sat May 19 2018 3:20am |
