Home > Maintenance & Modifications > L322 2013 Autobiography .Bonnet/Hood misalignment issue |
Rusty Novice Member Since: 04 May 2018 Location: Staffordshire Posts: 34 |
Fri May 04 2018 8:47pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4844 |
Have you tried loosening the two 13mm headed bolts shown in the picture with the paint missing ?, as it looks like someone has already had a spanner on them, as they appear to be the only visible bolts when I had a quick look at mine.
Fri May 04 2018 9:32pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
I had a similar issue but at the bonnet catch end. Took me a little trial and error to get it just right. I think Col has it right, I bet if you just slacken those bolts, you will find the holes in the hinge are oversize to allow adjustment. As said the give away that they have been messed with is the paint marks. I also had to adjust the wing a little and used an adjustable spanner with insulation tape on the jaws to prevent paint damage to the bolts. Worked a treat. 2012 5.0 SC AB
Fri May 04 2018 11:20pm |
Yes I did note the paint damage on those bolts and think the same .Regarding oversized the adjustment I need would mean they would have to be elongated but nothing ventured nothing gained .
Sat May 05 2018 6:55am |
Just had a look on eBay and the holes are indeed elongated for vertical adjustment.
Sat May 05 2018 8:11am |
Yep
Sat May 05 2018 7:44pm |
The bolt head size was only a quick guess sorry, by the way the Sport is a L320 the L322 is the earlier Fullfat.
Sat May 05 2018 10:02pm |
