Home > Technical > P0128-00 (E8) 2007 RRS |
The cooling fan should not run continually it should come on when first started then only come on when needed if its on all the time you will here it making quite a noise |
Wed Mar 14 2018 7:36pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
are they not engine driven fans (vicious)? like the diesel ?
Wed Mar 14 2018 7:57pm |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
Hello Wacko
Wed Mar 14 2018 8:05pm |
Wacko Member Since: 03 Sep 2016 Location: Chilliwack BC Posts: 6 |
How long should it run after start up? |
Wed Mar 14 2018 8:57pm |
mechanical ones will always move around
Wed Mar 14 2018 9:27pm |
I here my for about 10-20 seconds quite loud then it’s all quiet |
Wed Mar 14 2018 9:50pm |
Any recommendations on what would cause my fan to run constantly? Is it a bad relay or clutch? Do I need to replace the fan?
Wed Mar 14 2018 11:15pm |
A little update. My fan does appear to be spinning when ever engine is running however it isn't overly loud. I unplugged it and started the engine and it continued to spin. With the engine off I can spin the fan with my had but there is slight resistance. Is this normal or should it free spin with no resistance.
Thu Mar 15 2018 3:39pm |
Hi Wacko,
Thu Mar 15 2018 4:13pm |
Socast,
Thu Mar 15 2018 4:53pm |
The V8's can be a pig to bleed |
Thu Mar 15 2018 7:42pm |
Could air in the system cause too much cooling? My problem is the engine isn't getting up to proper engine temperature |
Thu Mar 15 2018 7:44pm |
