Home > General > VIN on chassis |
Front offside chassis member viewed through front wheel arch In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sat Mar 10 2018 11:52am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4789 |
I thought you got under the car (below the drivers door) and it was stamped onto the beam.
Sat Mar 10 2018 12:15pm |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 |
I have had a good luck at the front chassis through the wheel arch and cannot find anything. SWMBO has just gone out in the car and so will look under the drivers door chassis when she returns. Thanks for your time guys and hope to find it sooner rather than later. Ironically when I first got the vehicle I put the side steps on it and I should have had a good look then Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Sat Mar 10 2018 12:29pm |
Thanks Andy K, found it after putting extended mode on car and then rubbing my fingers on the chassis til I found it exactly where you said. Bit surprised that it isn't actually stamped on the chassis but appears to be on a plastic film attached to the chassis. Luckily it is in silver so I was able to get a photo of it....just. Attached pic so that if anybody else needs to look for it in the future you will know what to look for.
Sat Mar 10 2018 3:01pm |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 407 |
...under the front right (passenger) door, on the chassis. The number is facing you on the chassis. Use baking soda to remove rust. Barrie.
Thu Jul 19 2018 6:57pm |
