![]() | Home > Faults & Fixes > Fault code c1A00 |
Tyrefitter Member Since: 19 Jul 2015 Location: East Yorkshire Posts: 1529 ![]() ![]() ![]() |
It could be a stored code,problem might have been fixed but code not removed at time of fix |
Wynne1991 Member Since: 28 Dec 2017 Location: Flintshire Posts: 11 ![]() ![]() ![]() |
Could be I cleared faults didn't check if it did clear can check tomorrow ,when applying the hand brake it makes a loud sqwelling noise could it be related ? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 1687 ![]() ![]() ![]() |
That code relates to Terrain Response Switchpack.
glennp123 Member Since: 04 Dec 2017 Location: Northern Ireland Posts: 24 ![]() ![]() ![]() |
sounds to me like your handbrake control module isn't working! if it makes a loud screech noise im afraid. That fault code is the same one a diagnostics machine gave me when my handbrake wasn't working, but it turned out in my case it was broken wires going to the switch... however your symptoms point towards the module itself with the loud noise. |
