Home > Faults & Fixes > Fault code c1A00
Wynne1991
Wales 2005 Range Rover Sport TDV6 HSE Siberian Silver
Fault code c1A00
Hi I have fault c1A00 -control module as a permanent fault in the abs system ! No faults on dash just off diagnostics any help
Post #544340 Fri Dec 29 2017 9:42pm
Tyrefitter
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
It could be a stored code,problem might have been fixed but code not removed at time of fix Thumbs Up
Andy. 2014 RRS SC santorino,coris roof.
2016 VW Amarok Highline,candy white
2014 Evoque D-Lux Fuji
Previous motor.
2014 RRS AB FUJI
2012 RRS Dynamic red edition Fuji
2012 RRS SE santorino
2015 Navara White
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #544341 Fri Dec 29 2017 9:48pm
Wynne1991
Could be I cleared faults didn't check if it did clear can check tomorrow ,when applying the hand brake it makes a loud sqwelling noise could it be related ?
Post #544342 Fri Dec 29 2017 10:05pm
That code relates to Terrain Response Switchpack.
The terrain response
switchpack has
indicated a
calibration/parameter
memory failure for
embedded systems.
Post #544343 Fri Dec 29 2017 10:06pm
glennp123
United Kingdom 2007 Range Rover Sport TDV8 HSE Firenze Red
sounds to me like your handbrake control module isn't working! if it makes a loud screech noise im afraid. That fault code is the same one a diagnostics machine gave me when my handbrake wasn't working, but it turned out in my case it was broken wires going to the switch... however your symptoms point towards the module itself with the loud noise.
Post #545038 Sun Jan 07 2018 2:16pm
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
