Home > Faults & Fixes > EPB *SORTED* now working, but NO DASH "P" light?? |
Front lower arms for the knocking you will need them done for the mot not to sure about but if you cant here the hand brake when you pull the switch then it is not working as you have worked out but if the snap on tool works it then not sure about epb |
Mon Dec 04 2017 9:01pm |
glennp123 Member Since: 04 Dec 2017 Location: n.ireland Posts: 36 |
i have done some more research on the EPB. Apparently there are 2 connectors above the p/s rear wheel which run up to the switch and its common for these to start rubbing cause of the wheel against a bit of plastic covering them! Gonna check it out ASAP.
Mon Dec 04 2017 9:03pm |
There are a few places that rub and a few connectors that get corroded have a look on the sister site disco 3 as they are pretty similar to the sport on many things |
Mon Dec 04 2017 9:07pm |
Heres what im seeing lying underneath just. |
Mon Dec 04 2017 9:21pm |
I spotted those..almost unprotected wires the other day, ridiculous design! Only had mine less than 3 months and I`m becoming disillusioned with it. Steve. |
Wed Dec 06 2017 12:35pm |
UPDATE!
Sat Dec 16 2017 7:40pm |
No it dosent but if it well looked after cleaned and adjusted properly it will never really go wrong either |
Sat Dec 16 2017 7:47pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
4.5 years without an EPB issue
Sat Dec 16 2017 9:13pm |
Does anyone know why the dash isnt getting the signal now to put the "P" red symbol light on the dash?
Tue Dec 19 2017 2:53pm |
