Home > Faults & Fixes > Heater blower either off or on max speed
Fictivision
Norway 2006 Range Rover Sport TDV6 HSE Santorini Black
HEy guys,I got a problem with heater blower last few days.When AC is on, on whatever speed the blower always runs on top speed,but it turns off when OFF button is pressed.
I guess there must be some fault with a component/sensor at the blower motor itself, how hard is it to get to the blower and fix this problem?Can this be a ressistor or something else?
My car is an 2006 RRS 2.7TDV
Thanks in advance
Post #535881 Tue Sep 19 2017 12:09pm
Eaters
Sorry if this is a stupid question, but you have tried turning the knob haven't you? Robin
Awaiting rebuild: NGTF
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #535905 Tue Sep 19 2017 6:33pm
Fictivision
Yeah,and lights at the knob indicates what speed blower should spin but the blower keeps constant max speed unless i turn knob all the way to the left till it turns off.
Post #535916 Tue Sep 19 2017 8:48pm
Johnski
Is there a dropper resister fitted for this, was in the "old" days, but could well have been modified nowadays. Embarassed John
Post #535936 Wed Sep 20 2017 1:06am
RR JOHN
United Kingdom 2006 Range Rover Sport 4.4 V8 HSE Sumatra Black
It's most likely the resistor module located next to the fan below your glove box. It is housed through the side of your duct leading from the fan motor and retained by 2 Philips screws. A 4 spade connector is plugged into it. £45 is the usual cost of these so I stripped mine down by prising the grey body over the spades to reveal a circuit board. I found a thermal fuse value 114° and 2 amp rating. R replaced it making sure it was sunk into the semiconducting white goo.(I added more of this goo to be sure that the heat was dissapated into the cooling fin's from/to the fuse. At a cost of less than £1 for the fuse it resolved the problem. HAPPY DAYS !!!
Post #541368 Sun Nov 19 2017 7:15pm
RR JOHN
The thermal fuse is a small white component and is soldered to the circuit board. So you will need a decent little solderer.
NOTE: Try not to go overboard using loads of solder otherwise you will ruin or short out the circuit board.
Post #541370 Sun Nov 19 2017 7:19pm
Fictivision
thanks alot RR JOHN i will see if I can resolve this problem.
Post #541391 Sun Nov 19 2017 8:53pm
RR JOHN
If I can help further just reply here
Post #541392 Sun Nov 19 2017 9:05pm
Eaters
Any pics of what you find and do might be really useful for others if you can Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #541405 Mon Nov 20 2017 12:04am
