Home > Faults & Fixes > Heater blower either off or on max speed |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
Sorry if this is a stupid question, but you have tried turning the knob haven't you? Robin
Tue Sep 19 2017 5:33pm |
Fictivision Member Since: 31 Oct 2015 Location: Molde Posts: 31 |
Yeah,and lights at the knob indicates what speed blower should spin but the blower keeps constant max speed unless i turn knob all the way to the left till it turns off. |
Tue Sep 19 2017 7:48pm |
Is there a dropper resister fitted for this, was in the "old" days, but could well have been modified nowadays. John
Wed Sep 20 2017 12:06am |
RR JOHN Member Since: 19 Nov 2017 Location: Cannock Posts: 3 |
It's most likely the resistor module located next to the fan below your glove box. It is housed through the side of your duct leading from the fan motor and retained by 2 Philips screws. A 4 spade connector is plugged into it. £45 is the usual cost of these so I stripped mine down by prising the grey body over the spades to reveal a circuit board. I found a thermal fuse value 114° and 2 amp rating. R replaced it making sure it was sunk into the semiconducting white goo.(I added more of this goo to be sure that the heat was dissapated into the cooling fin's from/to the fuse. At a cost of less than £1 for the fuse it resolved the problem. HAPPY DAYS !!! |
Sun Nov 19 2017 6:15pm |
The thermal fuse is a small white component and is soldered to the circuit board. So you will need a decent little solderer.
Sun Nov 19 2017 6:19pm |
thanks alot RR JOHN i will see if I can resolve this problem. |
Sun Nov 19 2017 7:53pm |
If I can help further just reply here |
Sun Nov 19 2017 8:05pm |
Any pics of what you find and do might be really useful for others if you can Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Sun Nov 19 2017 11:04pm |
