Home > Maintenance & Modifications > Instrument binnacle cover replacement |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
It is not to difficult to change, but to make life easier you will need to remove the steering wheel first as you need to remove the instrument cluster to get at the screws behind which secure the pod. It is possible to get the cluster out without removing the wheel, but as space is limited there is a very strong possibility of scratching the cluster front, and also marking the leather with the sharp edges of the plastic. You need to remove some of the plastic bezels around the steering column as well as a plastic bezel under the pod and in front of the cluster which is a bit awkward as it is clipped in and you have to give it quite a tug to release it, and again the leather can be marked by the sharp edges if not careful.
Mon Sep 18 2017 10:53pm |
thomas brown Member Since: 29 Mar 2016 Location: Norwich Posts: 559 |
Hi guys.
Tue Sep 19 2017 8:53am |
