Home > Technical > iid tool |
It should come on when the temp drops below 5-6 degrees or if you read the manuel on the IID tool website it tells you how to test fire it |
Sun Sep 10 2017 6:33pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4789 |
I think u need to buy a £250 part to be able to turn it on from your remote key |
Sun Sep 10 2017 6:40pm |
Have a look here
Sun Sep 10 2017 6:49pm |
Beeawreet Member Since: 10 Sep 2017 Location: Lincs Posts: 8 |
hi thanks for the info/suggestions..the altox thread is for a disco.?.does this apply to me.?...although the iid tool would be useful for so many more things I need to know if a range rover sport 2008 has the option for timed park heating.(therefore able to blow warm air into the cabin) hidden in the ecu files and able to be enabled)..as buying the diagnostic tool would be an expensive experiment if its an impossibility..thanks. |
Sun Sep 10 2017 7:49pm |
They are very similar cars and you would need a kit to turn on the fbh as that software was removed on earlier cars including yours i would suspect with a software update from land rover why do you ask if you can turn it on and by the way having access to IID tool or similar is almost a must with these cars or knowing a friendly indi who can help |
Sun Sep 10 2017 8:05pm |
You don't need to enable anything on your year car, you just need to fit the Altox kit that I sell (just taken another delivery in prep for winter!)
Sun Sep 10 2017 8:16pm |
Ok I think I will go with the altox suggestion and also invest in the iid tool..thanks for the forums help. |
Mon Sep 11 2017 8:46am |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 |
Any dates yet on when the tool might be updated to enable MY17 cars with FBHs? |
Mon Sep 11 2017 10:07am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
Bodsy can supply and fit it for you and you won't need to buy an iiid too saving you dosh...and he's mobile Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * Current: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
Mon Sep 11 2017 11:52am |
Ok thanks for that Donny dog. |
Mon Sep 11 2017 3:22pm |
