Home > Maintenance & Modifications > Aux pump |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
Just reverse wires.
Sun May 28 2017 7:54pm |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
It is recommended it is replaced. Apparently it fails rather quickly after reversing the wires. Check out my gallery. It has the tsb. MY12 RRS HSE
Sun May 28 2017 9:07pm |
Don't quite understand why it would fail if you just reversed the wires to be honest and can't see anything on tsb about reversing the wires or am I just being a bit thick |
Sun May 28 2017 9:43pm |
Hello geoff
Sun May 28 2017 9:49pm |
Thanks shep what's the difference between a ls and a lm Range Rover Tia |
Sun May 28 2017 10:52pm |
LS is your sport |
Sun May 28 2017 11:41pm |
Mon May 29 2017 6:47am |
Thanks everyone for info where is best place to get a new pump |
Mon May 29 2017 3:01pm |
I got mine approx 7 years ago. It was only £119 from Landrover. Which isnt to bad considering its on permanently. I think they are nearer 150 now, but definitely worth checking with the dealers first, I've found loads of parts cheaper from Landrover rather than eBay etc. May be worth giving Duckworth a pm. MY12 RRS HSE
Mon May 29 2017 7:43pm |
Just pm'd him seen them on the bay for £105 and stated as genuine
Mon May 29 2017 8:14pm |
Well just changed my pump and wires still find it hard to believe that this has not been sorted on a 12 year old car it looked at when i started to take it all apart it did actually look like the pump was disconnected |
Sun Jun 04 2017 10:59am |
