Home > Faults & Fixes > park brake fault
rostan242@gmail.com
park brake fault
urgently needs help
after turn on the engine pops up information park brake fault only
after driving a few mils pops up warning amber lights on dashboard
and here begins the problem, I do not know why but when you see the orange light park break problem
consumption car fuel has nearly doubled
please help
Post #520843 Tue Mar 14 2017 10:40am
Camelrock
Mpg could of increased because the park brake is binding. Do the rear wheels feel hot after a journey ? If you have warning lights coming on then the hand brake needs checking anyhow. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2018 Discovery 5 HSE lux current
1994 Dakar current
Post #520846 Tue Mar 14 2017 11:19am
geoffsnook
Does sound like binding rear breaks can you smell anything Thumbs Up
Post #520847 Tue Mar 14 2017 12:15pm
rostan242@gmail.com
Check it out when I come back from work but this is an important clue
It means that the handbrake cables. not open in a whole?
and still is applied gently handbrake ??
Thank you for your help, I hope that it will help solve the problem
Post #520848 Tue Mar 14 2017 12:27pm
rostan242@gmail.com
I checked, and unfortunately nothing smelled and did not block took off my drum,everything looks ok
and the most frightening is that after showing an error on dashbord is fast change range and Tip fuel goes down but after turn off ond on again back tu normal.always show amber light after 2-3 mil drive
nightmare help
Post #520950 Tue Mar 14 2017 11:09pm
DrRob
Find a good independent LR mechanic.....
Bodsy and Flack are mobile, live in NW and are site sponsors Visitor from fullfatrr.com
* Current: 2011 4.4 TDV8 Full Fat. Amazing piece of kit.
Post #520983 Wed Mar 15 2017 11:16am
rostan242@gmail.com
probably I will have no choice
only problem is that in the UK the mechanics they go the easy way, do not fix things exchange for new elemety and it costs a fortune
Post #520987 Wed Mar 15 2017 11:24am
DrRob
Bodsy or Flack will sort it for you
Search for them on here Visitor from fullfatrr.com
Post #520999 Wed Mar 15 2017 1:13pm
rostan242@gmail.com
problem finded by delphi fault code U0417 Invalid data received from parking brake control module
but i dont know what to do
Post #521213 Fri Mar 17 2017 9:25pm
geoffsnook
Have a look here last post on the page will give you a starting point as you appear to have a wiring issue Thumbs Up
http://www.disco3.co.uk/forum/topic124238.html?highlight=U0417
Post #521295 Sat Mar 18 2017 2:47pm
rostan242@gmail.com
problem found. cracked tape in inside the brake module
thanks for help
Post #521451 Mon Mar 20 2017 6:55pm
DrRob
Tape? Intrigued Whistle Visitor from fullfatrr.com
Post #521463 Mon Mar 20 2017 8:10pm
rostan242@gmail.com
I mean this tape from photo,During the last brake repair, I did not have to install the casing properly I crushed the tape
But I fixed it Very Happy
Post #521466 Mon Mar 20 2017 8:38pm
