Home > Faults & Fixes > park brake fault |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Mpg could of increased because the park brake is binding. Do the rear wheels feel hot after a journey ? If you have warning lights coming on then the hand brake needs checking anyhow. 2008 G4 RRSport TDV8 current
Tue Mar 14 2017 11:19am |
Does sound like binding rear breaks can you smell anything |
Tue Mar 14 2017 12:15pm |
rostan242@gmail.com Member Since: 15 Sep 2016 Location: Alfreton Posts: 28 |
Check it out when I come back from work but this is an important clue
Tue Mar 14 2017 12:27pm |
I checked, and unfortunately nothing smelled and did not block took off my drum,everything looks ok
Tue Mar 14 2017 11:09pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
Find a good independent LR mechanic.....
Wed Mar 15 2017 11:16am |
probably I will have no choice
Wed Mar 15 2017 11:24am |
Bodsy or Flack will sort it for you
Wed Mar 15 2017 1:13pm |
problem finded by delphi fault code U0417 Invalid data received from parking brake control module
Fri Mar 17 2017 9:25pm |
Have a look here last post on the page will give you a starting point as you appear to have a wiring issue
Sat Mar 18 2017 2:47pm |
problem found. cracked tape in inside the brake module
Mon Mar 20 2017 6:55pm |
Tape? Intrigued Visitor from fullfatrr.com
Mon Mar 20 2017 8:10pm |
Mon Mar 20 2017 8:38pm |
