Home > Technical > Do I need a new battery? |
I get that when installing cd's onto the hard drive without the engine running. I checked the battery with a multimeter and while I can't remember the voltage, I do know it was still good (I'm an electrical engineer, so know a little about voltages...)
Sun Jan 08 2017 7:47pm |
Believe it or not leaving doors/ tailgate/ bonnet open on a Mk1 RRS is about the easiest way to flatten the battery! The warning has come up when there was enough energy left to start the engine, so maybe you just need a 20-30 mile trip to get the charge back into it. If you are still on the original battery then it may be on it's way out and with some very cold and snowy weather being forecast for the end of the coming week that might be enough to take it over the limit, might be a wise precaution to replace it now before the end of the week. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Jan 08 2017 7:52pm |
While the safest option, it's a comparable fix to cracking a nut with a fencing mall... I've had that dash warning several times now when both loading cd's, and also vacuuming the car, but on all occasions the battery voltage was fine. The car started fine, and it's often left for days between runs and then it runs for a maximum of 10 minutes at a time, so rarely gets a good charge. Infact I've been away from home now for over 3 weeks and my wife left the RRS for more than 2 weeks until she remembered to take it a run, and it started fine - and yes we also have the current cold Scottish weather. Of course my battery is a different battery, but what I'd be suggesting is to either get it tested properly, or look for additional signs of a failing battery, but to just replace it on the basis of the first dash warning is highly excessive and expensive (unless there is other history I'm not aware of?). 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Sun Jan 08 2017 8:07pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
Put a smart charger on it and give the battery a full charge. See how you get on from there. If you get the warning again in the next few weeks then it might be time to investigate further.
Sun Jan 08 2017 8:14pm |
