Home > Maintenance & Modifications > Trolley Jack & Axle Stands |
Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3675 |
you will be ok with a 2 ton jack as your only going to be lifting one corner at a time,,it also depends how much you want to spend & if the ground is level where your going to be jacking up.We use these & they are good if jacking up on uneven ground as they are wide.
Tue Sep 27 2016 12:43pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
I use this one with the 6 ton stands: https://www.machinemart.co.uk/p/ctj3000g-3...-garage-j/ Aside from the strength (and it is worth noting that the 3-ton Clarke quick lift jack has been known to fail under the weight of a D3) you also get more height available. Visiting from DISCO3.CO.UK
Tue Sep 27 2016 12:59pm |
Fish Member Since: 29 Jan 2014 Location: Glasgow Posts: 60 |
I went for this set http://www.sgs-engineering.com/garage-equi...xle-stands from SGS, very pleased with them and feel safe when working under all that steel 2.7 HSE, Audi A6 Exec, Honda Accord Exec, Volvo 440, Volvo 360 |
Tue Sep 27 2016 2:21pm |
Blueskye1 Member Since: 10 Sep 2016 Location: Carmarthen Posts: 80 |
Thanks Gents..
Tue Sep 27 2016 3:04pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
I bought SGS after a lot of research on Disco3 sister site
Tue Sep 27 2016 6:01pm |
Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118 |
I borrowed a 2 ton trolley jack and it wouldn't lift mine. Got a 3 ton sealey jack for around £35 and a pair of stands from argos around £20. |
Tue Sep 27 2016 7:53pm |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 863 |
A little off topic but I am looking for a good 2 ton light Weight Bottle jack to carry in the car. I don't like the jack supplied and if I need to change a wheel would like a better solution. Wondering if any of you guys have found a good solution. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Tue Sep 27 2016 10:32pm |
Gents thanks again for your words of wisdom
Tue Sep 27 2016 10:42pm |
tonywolf Member Since: 14 Sep 2015 Location: Devon Posts: 97 |
Hi IRBails, in answer to your query, I bought this item from LR Direct, and as you can see it fits nicely in the tool tray https://www.lrdirect.com/KAJ500151-supplie...ROVER.html Best Regards Tony MY2014 SDV6 AB Dynamic |
Wed Sep 28 2016 6:01am |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
That's the kit i received last week, it lifted and supported mine with absolutely no effort at all. Just be care full when you removing the axle stands when your finished, i raised the car up grabbed the axle stand and lifted the ratchet to free the support arm, it dropped down a wee bit quicker than i thought and i didn't quite move my little finger out the way in time. A week later and huge blood blister, swelling and rather tender joint, I'm slowly getting its use back..lol |
Thu Sep 29 2016 8:49am |
Cheers Dan
Thu Sep 29 2016 3:23pm |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
I very recently purchased the same Jack but not with those stands, was very disappointed that not a trace of oil etc in the Jack at all, and it was extremely difficult to remove retaining clip.(badly bent).
Fri Sep 30 2016 1:01am |
