Home > Faults & Fixes > Swimming pool inside
blacksportdave
My first post on here as I have not had the range long. I've just got back from holiday in Spain, had some rain over there but it seems the rain you have had in England has all landed inside my range!
I have just had the vax out and got out about a litre and a half of water!!
From the drivers front and rear side. Anyone git any ideas? I can't see where it's getting in for the life of me!
Dave
Post #503285 Sat Aug 20 2016 3:40pm
deano_123
Door seals?
Post #503288 Sat Aug 20 2016 4:24pm
blacksportdave
They all seem fine tbf mate, I'm going to get the hose out at some point and just see if I can see where it's coming from. When I pull off a ton of water pours out of the ceiling light so I'm guessing it's got something to do with the sunroof Confused
Post #503291 Sat Aug 20 2016 5:03pm
Jaggs
Drain tubes maybe blocked, not sure where they exit on the rrs but sure someone will Nanocom Evo
Post #503293 Sat Aug 20 2016 5:21pm
blacksportdave
The old man said about the drain pipes. I'm going to have to rip a few bits off and have a look
Post #503294 Sat Aug 20 2016 5:32pm
Jaggs
Usually down A pillars at front and back pillers at rear or they were on my d2
might just be blocked at top open sunroof and have a look on corners, careful sticking things down them if they are like the d2 you can break them off all too easy Nanocom Evo
Post #503295 Sat Aug 20 2016 5:46pm
blacksportdave
I did think the pillars, I've looked at the sunroof and seen a drain pipe each side. And from the light down to the flood it's bone dry (apart from the actual light unit) I will have a mooch tomorrow and see if I can see anything. Comes to something when a car that is ment to keep out the water let's it in more than any car I have ever had ha ha
Post #503297 Sat Aug 20 2016 5:51pm
BigBen
Saw a good tip on tele for finding the fault. Use a smoke machine inside car and of course shut doors!! The smoke quickly showed where gaps in seals were.
Post #503333 Sun Aug 21 2016 9:44am
blacksportdave
Good idea, funny enough I have got a smoke machine as I used to be a mobile dj ha ha. I will give that a go today Very Happy
Post #503338 Sun Aug 21 2016 10:06am
blacksportdave
All sorted, turned out to be the drain on the drivers side in the sunroof guttering. Got 1 peice of 1mm copper wire (I'm an electrician so it's all I had to hand) and fed it down the pipe. Hey presto all sorted. But I now have a problem with it pulling away at low revs, it's got better today so hopefully it's just because the water has effected something and will continue to dry out and fix itself so to speak Very Happy
Post #503402 Mon Aug 22 2016 7:50am
