Home > Faults & Fixes > Swimming pool inside |
deano_123 Member Since: 13 Aug 2015 Location: Newcastle Posts: 108 |
Door seals? |
Sat Aug 20 2016 4:24pm |
blacksportdave Member Since: 05 Jul 2016 Location: Birmingham Posts: 12 |
They all seem fine tbf mate, I'm going to get the hose out at some point and just see if I can see where it's coming from. When I pull off a ton of water pours out of the ceiling light so I'm guessing it's got something to do with the sunroof |
Sat Aug 20 2016 5:03pm |
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 |
Drain tubes maybe blocked, not sure where they exit on the rrs but sure someone will Nanocom Evo |
Sat Aug 20 2016 5:21pm |
The old man said about the drain pipes. I'm going to have to rip a few bits off and have a look |
Sat Aug 20 2016 5:32pm |
Usually down A pillars at front and back pillers at rear or they were on my d2
Sat Aug 20 2016 5:46pm |
I did think the pillars, I've looked at the sunroof and seen a drain pipe each side. And from the light down to the flood it's bone dry (apart from the actual light unit) I will have a mooch tomorrow and see if I can see anything. Comes to something when a car that is ment to keep out the water let's it in more than any car I have ever had ha ha |
Sat Aug 20 2016 5:51pm |
BigBen Member Since: 15 Dec 2015 Location: Hertfordshire Posts: 88 |
Saw a good tip on tele for finding the fault. Use a smoke machine inside car and of course shut doors!! The smoke quickly showed where gaps in seals were. |
Sun Aug 21 2016 9:44am |
Good idea, funny enough I have got a smoke machine as I used to be a mobile dj ha ha. I will give that a go today |
Sun Aug 21 2016 10:06am |
All sorted, turned out to be the drain on the drivers side in the sunroof guttering. Got 1 peice of 1mm copper wire (I'm an electrician so it's all I had to hand) and fed it down the pipe. Hey presto all sorted. But I now have a problem with it pulling away at low revs, it's got better today so hopefully it's just because the water has effected something and will continue to dry out and fix itself so to speak |
Mon Aug 22 2016 7:50am |
