Home > In Car Electronics > how to hardwire into fuse box
Wilson
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Can anyone point me to a guide or give me basic instructions how to add equipment to the fuse box?
I see there is a piggy back thingy you can buy, looks very easy but I'd rather do it properly if possible... unless of course this piggy back /adding to an existing fuse is proven to be 100% safe and reliable... Its only to hardwire a 12v to 5v converter for a fixed phone charger.
I was considering (as per previous post) to wire directly behind the cigarette lighter! this is still an option if experts on here think it will be ok?
Post #476463 Thu Oct 15 2015 12:10pm
jasons
2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
I added a piggy back fuse (from Amazon) last weekend to run my dash cam.
Easier than going in under the lighter and no wires to splice/ cut.
Definitely easier it insert when the glove box is pulled down to access the fuse box.
J
Post #476496 Thu Oct 15 2015 7:19pm
Bodsy
Site Sponsor
I've used piggyback fuses for years, never had one with an issue if designed as used.
The cameras are really low power, and with its own fuse, is safer than cutting into existing wiring. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #476519 Thu Oct 15 2015 8:51pm
muddywheels
Milk Float Man
Take a look here for information http://www.rrsport.co.uk/forum/topic28640.html?highlight=blackvue Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #476523 Thu Oct 15 2015 9:26pm
Wilson
Ok, piggy back it is then Thumbs Up
Our fuses are Mini aren't they? Not micro?
I guess I'll go off 52 ciggy lighter like in that post, as a fixed car charger will only be used when ignition is on.
Post #476531 Thu Oct 15 2015 10:57pm
Bodsy
Site Sponsor
On an 07 it's Mini Thumbs Up
Fuse 58 wakes up when you unlock the car as its the entertainment system. But the ciggy fuse would be fine as well. Bodsys Brake Bible
See it HERE
Post #476545 Fri Oct 16 2015 8:43am
Wilson
Cheers Bodsy Thumbs Up
Post #476551 Fri Oct 16 2015 9:04am
Lefty65
2006 Range Rover Sport TDV6 HSE Zambezi Silver
Bodsy I'm a newbie so can't pm you,but how much do you charge for Bluetooth upgrade,and a totally different question,if I take the fuse out for the DR can I still use the car safely,ie will it still drive normally many thanks lefty 65
Post #477092 Mon Oct 19 2015 11:06pm
Bodsy
Site Sponsor
Lefty, I'll drop you a message. Thumbs Up Bodsys Brake Bible
See it HERE
Post #477097 Tue Oct 20 2015 12:18am
Wilson
I've got all my bits to have a go at this now, just wondered if anyone can advise a good earth on/near the fuse box?
Thanks
Post #477395 Thu Oct 22 2015 2:38pm
mnk
Open the panel which is part of the bonnet release handle. Behind this panel you will see 3/4 bolts to the chassis with black wires - Any bolt should do the trick.
Post #477397 Thu Oct 22 2015 2:42pm
Wilson
Thanks MNK, I think I know the ones you mean, but I'm talking about the interior fuse box in this case, apologies wasn't very clear.
Post #477398 Thu Oct 22 2015 2:51pm
Bodsy
Site Sponsor
As mentioned above, just means you need to run the neg wire down to it.
Or you can also use one of the silver screws that you can see when you drop the lower glovebox. That will work fine as well in this case. Thumbs Up Bodsys Brake Bible
See it HERE
Post #477399 Thu Oct 22 2015 3:07pm
Wilson
Done it and all working fine... Used the silver screws below the glove box!
Thanks for you lots advise Thumbs Up
Post #477455 Thu Oct 22 2015 9:54pm
Bodsy
Site Sponsor
Thumbs Up Thumbs Up Bodsys Brake Bible
See it HERE
Post #477517 Fri Oct 23 2015 10:17am
