Home > Technical > Low fuel warning on a full tank, then judder and cut-out! |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4339 |
Wiring issue in the OSF wheel arch is fairly common, or a faulty sender unit, inside the tank |
Sat Oct 10 2015 2:12pm |
Ovey Member Since: 21 Jan 2015 Location: Portsmouth area Posts: 80 |
Thanks Disco_Mikey, I can only see wiring for the brakes (sensors I assume) in the OSF wheel arch? Whereabouts is the wiring for the fuel system?
Sat Oct 10 2015 2:16pm |
It turned out to be the fuel sender/fuel sender loom, which I had to pay for due to the car being 37 months outside warranty. (LR offer "goodwill" for 36 months outside of warranty apparently; although I suspect their goodwill lasts one month less than the age of ANY car)!
Wed Oct 21 2015 4:25pm |
And the business manager of Guy Salmon Portsmouth has just been on the phone to me - she's going to credit my card with the bill amount and has told me to take the wife out for a meal and send her the bill (she'll send me a cheque)!!
Thu Oct 22 2015 4:05pm |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 |
Now I am concerned
Sun Oct 25 2015 8:43pm |
Yeah, as it was explained to me, the car "starts a mileage count-down timer" as the low fuel warning appears. The ECM doesn't know it is spurious (due to dodgy tank sender) so it believes the owner is ignoring the low fuel warning and eventually gives you a couple of splutters (to warn you it's going to cut out) and then cuts out in order to prevent you from running out of fuel (not a good thing to do in modern RRS/Discos).
Mon Oct 26 2015 2:09pm |
awhittle Member Since: 23 May 2015 Location: United Kingdom Posts: 1 |
@Ovey I have exact the same issue on my 2011 RRS - fuel light, then gone to juddering, now cuts out, but starts again every time.
Tue Jan 12 2016 11:33pm |
it may be worth you talking to a main dealer
Thu Jan 14 2016 11:58pm |
Hi all,
Mon Jan 18 2016 4:51pm |
