![]() | Home > General (L494) > Anyone hardwired a dashcam in L494? |
| rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879
There are quite a few people advertising fitting of the cameras including Blackvue who have a network of nationwide fitters at there disposal. The price was £144 if i remember correctly 2012 3.0 SDV6 Luxury gone, but a great motor |
The fuses i think are as you say micro 2 ATR and are not easy to find anywhere especially if you want piggy back fuses. I eventually found a UK company called Costar who stock them. The piggy backs are item number 6029 @ about £2.50 each. As soon as mine turn up I will confirm that they are the correct type MY16 AUTOBIOGRAPHY Indus silver with some toys 2012 3.0 SDV6 Luxury gone, but a great motor |
| fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216
Thanks rigsby |
They arrived this morning and are the correct type 2012 3.0 SDV6 Luxury gone, but a great motor |
thanks Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
I have also ordered. Did yours come with 15 Amp fuses or do they have built-in fuses (so you only have to add 1 fuse of your own) rigsby? They just have the 5 Amp fuses in that size advertised on their website. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Hi, no they didn't come with any fuses but there is a spare fuse of each size in the fusebox that could be used |
Great Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Just seen this from an earlier thread by philm
Which trailer fuse did you use? F15 or F54? I initially used F15 and found it wasn't permanently live so went for F54 instead and my camera stays on until the number of days or battery voltage threshold on the Power Magic is reached. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
I went for f54 and f44 but i may have a not very good connection as they were only temporary. Got to re run the cable anyway so I will check it all out properly |
Just been to the garage and had a look and I can see the light on the camera so it must be powered ok |
| eddkawasaki Member Since: 23 Feb 2015 Location: Lancashire Posts: 93
I fitted one of these to my car yesterday. One thing to add to this very helpful thread is that my car is a late MY15 the fuses used in it are standard micro fuses available from any high street auto parts company beginning with H. You can also get the Add a circuit devices from the same shop although they are located in the ICE section not the fuses section strangely.
| duvl Member Since: 21 Oct 2015 Location: Surrey Posts: 38
I bought a Thinkware F750 front & rear dashcam including parking mode and fitting from the RAC. Collected new RRS on Thur Dec 17th and dash fitted at home address on the 18th (last Friday). Fitter knew his stuff but some things I'd wish I'd known pre purchase. Did ask on another thread for advice but very little was forthcoming. Thanks to those that did help. Things to bear in mind!
| All times are GMT |
