Home > Technical > 2010 autobiography seat heating? |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 |
Hi All Range Rover Sports from 2010 onwards front seat heating is standard. From HSE upwards to the Autobiography the rear seats are also standard equipment. Climate control is also standard. The climate is part of the heater and air-con. So if your looking at an Autobiography then YES climate and front and rear heating will be there.
Sat Aug 22 2015 12:55pm |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 |
That car definitely doesn't have heated seats, if you look carefully you can see the heated seat buttons are missing.
Sat Aug 22 2015 5:21pm |
RRSCS Member Since: 07 Mar 2012 Location: Budapest Posts: 19 |
Thank you very much, for both of you.
Sat Aug 22 2015 6:52pm |
