Home > In Car Electronics > TDV6 alternator charging only 13.6v
maioo
Hi, please i need help Sad I have problem with alternator on my RRS.
After refurbishing alternator is showing only 13.6v on 3000 rpm. Before refurbishing (when he was damaged) shows only 12.5v
on 3000 rpm.
My question is, if the refurbished is bad or the problem may be elsewhere.
Thanks a lot.
Post #467477 Tue Jul 14 2015 9:40am
Lost for Words
What are your full symptoms? Question
It's not unlikely that the alternator is the culprit, in which case I suggest you buy a new OEM (Denso) alternator. Failure after refurbishment is quite common on these so it's not recommended. Thumbs Up
Also, it may help if you fill out your vehicle profile. (Is it 2.7 or 3.0?) Wink
Thumbs Up Visiting from DISCO3.CO.UK
Post #467558 Wed Jul 15 2015 9:01am
maioo
Thank you for answer. It's 2.7, 2007. LR service told me, that the blame will be badly repaired alternator.
Servis receipt of the complaint (badly refurbished alternator) and try repair it again.
symptoms were: red battery icon lighting cca 30 min. and then HDC fault, suspension fault, max speed only 30 mph.
Post #467565 Wed Jul 15 2015 11:02am
