It's not unlikely that the alternator is the culprit, in which case I suggest you buy a new OEM (Denso) alternator. Failure after refurbishment is quite common on these so it's not recommended.
Also, it may help if you fill out your vehicle profile. (Is it 2.7 or 3.0?)
Visiting from DISCO3.CO.UK
Wed Jul 15 2015 9:01am
maioo
Thank you for answer. It's 2.7, 2007. LR service told me, that the blame will be badly repaired alternator.
Servis receipt of the complaint (badly refurbished alternator) and try repair it again.
symptoms were: red battery icon lighting cca 30 min. and then HDC fault, suspension fault, max speed only 30 mph.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
