Home > Technical > Heads up on some warranty work feedback
BoldlyGo
Car's been in to Harwoods, Pulborough for some 'cosmetic' work.
Drivers front seat swab replaced due to leather wearing on outer seam, also replaced was the underlying foam cushion which was rucking.
All wheelnuts replaced due to rust, all drums cleaned of rust staining from the nuts.
Check under the driver and front passenger seat, there is a curved metal guard - both of mine were showing light dusting of rust, these have been replaced.
The issue of the upper door of the boot marking the paintwork of the main frame door resolved by a LR Bulletin, two rubber nipples now in place either side of the curtessy light and some plastic trim removed. Paintwork made good.
The discoloration of the rear seats (alpacca) caused by the LR seatcovers staining them in grey couldn't be removed (once covers removed it is far worse than prev tought) and a full set of alpacca leather seat swabs has been ordered for the whole rear seat area of the car. The waterproof Covers are now withdrawn for the RRS. We have asked that new swabs are not fitted until the new covers are available.
Noisy wiper blades replaced.
Software upgrade carried out.
The passenger side rear triangular window rubber has been ordered since the original rubber surround is breaking down.
Supercharged Grill fitted £140, ooops!! , but it does look good. Apparently LR are getting a bit fussy as to who buys the grills and are asking for Vin numbers before ordering them.. I had no prob though but I guess it could have already been in stock.
Car going bl##dy well !!
Regards to all........
New non LR aftermarket SatNav being fitted into the SE oddment tray, I think you will be impressed, will post with photos once all done. Wink P400e HSE Portofino Blue and Ivory Seats.. it's like a yacht!!
Lexus traded in ..a total piece of crap
Boldly now acquired - a Lexus RX 450hL
BoldlyGone...Sep 15 MY16 RRS SDV6, HSE, Barolo Black, Espresso/Almond interior.. Best car ever & Drop dead gorgeous... sadly with fuel dilution headaches that became intolerable
Arrived 2014. Oct - Lemoned March 2015- RRS SDV6 HSE
Boldly Gone = Sold for 14k via Pistonheads - 2006 TDV6 SE Buck Blue/Almond int
Post #55583 Fri Sep 15 2006 8:29am
Did you get the VEP work done, BoldlyGo? I've been very impressed with the way the car handles after having the suspension valves replaced under this programme.
Post #55585 Fri Sep 15 2006 8:34am
BoldlyGo
Bit more deet plse schmoogie, VEP ?, is that a scheduled upgrade? , I'll give the garage a call in a mom if you can give me a touch more detail.
Thkx P400e HSE Portofino Blue and Ivory Seats.. it's like a yacht!!
Post #55586 Fri Sep 15 2006 8:40am
Vehicle Enhancement Programme...
Look here for details.
Post #55587 Fri Sep 15 2006 8:43am
BoldlyGo
Checked with Harwoods, yep, VEP carried out as follows:-
- Electronic Air Suspension Compressor Upgrade (includes upgrade ride level control module software)
- Upgrade Engine Control Module Software
- Upgrade Transfer Case Control Module Software
- Upgrade Heating Ventilation and Air Conditioning Control Module Software
- Upgrade Instrument Pack Control Module Software
- Environmental Box (E-Box) Sealing Grommet Check
- Upper Tailgate Support Fixing torque, rattle repair
Can't wait to give it a good old go this W/E.
Appreciate you forcing the question smoogs. P400e HSE Portofino Blue and Ivory Seats.. it's like a yacht!!
Post #55590 Fri Sep 15 2006 8:54am
I had the VEP done quite some time ago when in for other warranty work. The car has driven 100% Ok since Very Happy
Boldygo = I see you have the noisy windscreen wiper syndrome - I still get this even after changing my wiper blades twice Evil or Very Mad
What to do next................ Banging Head
Post #55601 Fri Sep 15 2006 9:53am
No problem mate... Very Happy
Post #55603 Fri Sep 15 2006 9:58am
