Home > General (L494) > Climate control issue |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 |
I would add that having had the car since October, this has not occurred before. But last Thursday I changed the auto fan speed to minimum, and then changed it again to max on Saturday as it was quite warm! There's the coincidence! |
Mon May 19 2014 11:35pm |
mikef Member Since: 16 Sep 2013 Location: bucks Posts: 303 |
Good luck with getting your local stealer to rectify it. I am experiencing similar issues in my 2011 FFRR and I have put the car in to my stealer for rectification and both times, they have said there is nothing wrong with it. I have had many cars with climate control fitted and I know how its supposed to work but apparently my stealer doesn't. FWIW and in my case, I think it's something to do with the cabin temperature sensor malfunctioning |
Wed May 21 2014 2:41pm |
Thanks for the info. You may well be right! I think the hotter the cabin is, the more it upsets the sensor. All ok today, but it was a cool morning, and didn't use the car after mid morning. Saturday was 23-25 deg outside and stopped the fan/climate, Sunday 24 deg outside at 1600 hrs and stopped the fan/climate. |
Wed May 21 2014 10:24pm |
arwV8 Member Since: 17 Feb 2018 Location: Worcestershire Posts: 18 |
Did you ever resolve the issue. My my16 tdv8 is doing the same. Only when outside temp has been 27C and above so far!
Wed Jul 04 2018 1:32pm |
34 degrees today and it did it again in town after being parked for 30 minutes, its went very quiet, barely 30 seconds after firing her up, fans stopped running and the temp in the cabin rose quickly ..
Thu Jul 05 2018 7:05pm |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 411 |
I thought my air con was broken just the other week as it kept going off the automatic setting. It turns out my daughter was not just changing the temperature in the back (3 zone climate), she was also changing the fan speed - which turns of the automatic fan control in the front as well as the back. RRS MY17 SDV6 AB
Thu Jul 05 2018 10:55pm |
Interesting , had a read up of the climate system and it can allow that to happen. You can lock out the rear controls from the tft display menu so auto stays in the front occupants control. |
Thu Jul 05 2018 11:14pm |
So child proof locks required on 2019MY 3 or 4 zone climate control to prevent little fingers fiddling with the rear controls? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Jul 06 2018 8:17am |
Update, had several more occurrences so video'd every time it happened there after as evidence. My IID tool did not identify any fault codes. Talked to the service manager at Listers Hereford and he checked with the experienced techs to see if they had seen anything like it . A resounding no! So booked it in and took many videos that showed it occurring. They agreed there was problem and they saw no fault codes either.
Fri Jul 20 2018 5:01pm |
trafficman13 Member Since: 11 Oct 2016 Location: Wales Posts: 9 |
Any update mate. Did you sort the problem? |
Thu Aug 16 2018 6:52pm |
Hi Trafficman 13,
Thu Aug 16 2018 9:15pm |
Thanks for the update. I've got an aircon problem that I'm struggling to resolve, so was trying to establish some common de-nominators.
Thu Aug 16 2018 9:51pm |
Things to check
Fri Aug 17 2018 6:53pm |
