Home > Faults & Fixes > Adaptive Cruise Control issue - Help needed |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 |
What do you know indeed.... Back in your cage |
Tue Sep 25 2012 1:59pm |
Thank you. You're most kind.
Tue Sep 25 2012 2:02pm |
Mr Rox Member Since: 16 Sep 2012 Location: London Posts: 10 |
Arrrrrrgghhh.
Tue Sep 25 2012 8:58pm |
firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461 |
"It does not sound right if you say you need CC for ACC to work."
Wed Sep 26 2012 12:52pm |
Seen as uve been on the forum for a relatively short period of time u might not realise but Bobby is a RR Sport guru. Literally a fountain of knowledge. I'm certain that he knows the difference and more than likely down to the component part numbers. |
Wed Sep 26 2012 1:20pm |
X5pea thanks for editing your post, the bit at the end condescending to both parties... I really couldn't give a hoot if he designed it from the ground up (no offence Bobby, hopefully you can see were i am coming from ), my responses have an element of humour, a bit of tongue in cheek ! and FACT I also didn't realise that the length of time on the forum had any relevance to anything, my bad I have given my self 100 lines and detention..... If you took some fog and put it in a jar, would it be missed. Last edited by firstinretail on Wed Sep 26 2012 1:35pm. Edited 1 time in total |
Wed Sep 26 2012 1:31pm |
Your welcome old boy. I saw your thread regarding a service and thought that it would be much more fitting in there |
Wed Sep 26 2012 1:34pm |
Gentlemen, sorry for causing all this!
Thu Sep 27 2012 6:51am |
As with most forums a gentle bit of banter is to be had. I had no intention of upsetting you, making you feel bad or other nasties so please forgive me today I am going to flog myself until lunch time as recompense
Thu Sep 27 2012 8:15am |
Ok, so the car has been in with an authorised service centre. They discovered that there was a lose connection behind the steering wheel. Now they're having trouble re-calibrating the unit. The next step they're going to take is removing the front bumper to see if the unit is has somehow been knocked out of place. At the moment I have a yellow warning light symbolising a road with a car flashing on the dashboard...
Fri Nov 02 2012 8:06pm |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 |
ACC does not work near airports. CC does work near airports.
Fri Nov 02 2012 9:09pm |
Rats, another double post. |
iainp100 Member Since: 05 May 2011 Location: saddleworth Posts: 59 |
I have ACC and had the same error when i purchased mine it was a wire that had sanpped going throught to bumper A1 landrover diagnosed and sorted it for me for 90 all in Range rover Sport tdv8 with bas touch
Wed Dec 19 2012 4:55pm |
