Home > General > Slow to refuel |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
It might be that the misfueling device has been activated, if fitted |
Tue Nov 15 2011 8:34pm |
Tonyrec Member Since: 15 Mar 2009 Location: Cumbria Posts: 306 |
It is fitted but I thought that this would stop any fuel going in or is it ident to my symptoms? |
Tue Nov 15 2011 8:41pm |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
Sounds like misfuel device has dropped
Tue Nov 15 2011 9:52pm |
V8SC Member Since: 29 Oct 2011 Location: Hampshire Posts: 145 |
I've had a similar problem with other cars before and remember finding that if I turned the fuel filler hose about 90 degrees anti clockwise after inserting into the fuel filler, the slow fill problem did not occur. Sounds strange I know but might be worth a try. Its worked for me before. Good luck. Carl |
Tue Nov 15 2011 10:09pm |
Many thanks for the replies, I will try both methods and report back. |
Tue Nov 15 2011 10:17pm |
wackyjim Member Since: 12 Nov 2009 Location: Tayside Posts: 265 |
V8SC Is absolutely correct here...I am not sure that the misfuel device has actually activated itself more of a design problem and I have found in my FFRR that some filling station pumps are worse than others. I now do what V8SC suggests all the time and as such it doesn't bother me anymore |
Wed Nov 16 2011 6:28am |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 |
I don't bother with the yellow device, I am used to putting diesel in now after 2 consecutive RRSs, when I am re-fuelling....
Wed Nov 16 2011 8:56am |
I noticed this when filling mine up at the weekend. As said above, try moving the nozzle around a bit. The combination of the mis-fuel device and high volume pumps can cause the pump to 'shut off' prematurely. ON THE WAY: BMW F21 M140i
Wed Nov 16 2011 9:14am |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
check the tank vent too, air has to come out for fuel to go in ============
Wed Nov 16 2011 6:41pm |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 |
I just use the handle hold lock that all fueling hoses have here, much simpler '08 RRS TDV8 I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
Thu Nov 17 2011 10:59am |
La-de-da If we had those fuel would be another 5p pre litre |
Thu Nov 17 2011 1:00pm |
thanks to you is why there is always fuel on the bloody lever!!!! ============ 2010 TDV8 HSE - ooo laa laaaaaaaaa 2007 TDV8 HSE - superb car and very reliable ============ 2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8! |
Thu Nov 17 2011 5:58pm |
For the fuel click problem - ive had this before, move the nozzle out of the filler one notch.
Thu Nov 17 2011 7:31pm |
Gerico Member Since: 02 Jul 2011 Location: Essex Posts: 224 |
+1 |
Thu Nov 17 2011 8:05pm |
