Home > General > Slow to refuel
Tonyrec
Slow to refuel
I can't stop Mr. Green every time I drive our TDV8 but every time I have to refuel it takes an absolute age. It's just click, click after every 10p worth and it's sooooooo annoying Big Cry
Does anyone have this problem or can suggest anything please as its driving me nuts(only filled it up 3 times so far).
Post #321327 Tue Nov 15 2011 9:32pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
It might be that the misfueling device has been activated, if fitted Idea
Post #321329 Tue Nov 15 2011 9:34pm
Tonyrec
It is fitted but I thought that this would stop any fuel going in or is it ident to my symptoms?
Post #321333 Tue Nov 15 2011 9:41pm
Sounds like misfuel device has dropped
Reset the misfuel protection device as follows:
1. Insert the reset tool (with the teeth uppermost) as far as it will go into the filler neck.
2. Locate the teeth by pushing down the top of the reset tool.
3. With the top of the tool pressed down and the teeth engaged, slowly pull the tool out of the filler neck to reset the device.
Do not twist the device, once the teeth have engaged.
Post #321348 Tue Nov 15 2011 10:52pm
V8SC
2006 Range Rover Sport Supercharged Bonatti Grey
I've had a similar problem with other cars before and remember finding that if I turned the fuel filler hose about 90 degrees anti clockwise after inserting into the fuel filler, the slow fill problem did not occur. Sounds strange I know but might be worth a try. Its worked for me before. Good luck. Carl
Post #321351 Tue Nov 15 2011 11:09pm
Tonyrec
Many thanks for the replies, I will try both methods and report back. Thumbs Up
Post #321352 Tue Nov 15 2011 11:17pm
wackyjim
Scotland
V8SC Is absolutely correct here...I am not sure that the misfuel device has actually activated itself more of a design problem and I have found in my FFRR that some filling station pumps are worse than others. I now do what V8SC suggests all the time and as such it doesn't bother me anymore Smile
Post #321370 Wed Nov 16 2011 7:28am
Jonny Fresh
I don't bother with the yellow device, I am used to putting diesel in now after 2 consecutive RRSs, when I am re-fuelling....
**TOP TIP ALERT**
I wedge the filler cap under the handle and let the car fill up while I clear all the rubbish out etc.
When the car is full it clicks it self off, saves me standing there Thumbs Up
Post #321376 Wed Nov 16 2011 9:56am
I noticed this when filling mine up at the weekend. As said above, try moving the nozzle around a bit. The combination of the mis-fuel device and high volume pumps can cause the pump to 'shut off' prematurely. ON THE WAY: BMW F21 M140i
Post #321377 Wed Nov 16 2011 10:14am
rrsboy
check the tank vent too, air has to come out for fuel to go in Thumbs Up ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #321467 Wed Nov 16 2011 7:41pm
flydive
Jonny Fresh wrote:
**TOP TIP ALERT**
I just use the handle hold lock that all fueling hoses have here, much simpler Wink Mr. Green '08 RRS TDV8
Post #321538 Thu Nov 17 2011 11:59am
Jonny Fresh
flydive wrote:
Jonny Fresh wrote:
**TOP TIP ALERT**
La-de-da Laughing
If we had those fuel would be another 5p pre litre
Post #321552 Thu Nov 17 2011 2:00pm
rrsboy
**TOP TIP ALERT**
thanks to you is why there is always fuel on the bloody lever!!!! Censored ============
Post #321588 Thu Nov 17 2011 6:58pm
mse
For the fuel click problem - ive had this before, move the nozzle out of the filler one notch.
Its not the miss fuel device as that only stops all fuel Mike
2014 Facelift Discovery
Post #321598 Thu Nov 17 2011 8:31pm
Gerico
rrsboy wrote:
**TOP TIP ALERT**
+1 Censored Whistle
Post #321606 Thu Nov 17 2011 9:05pm
