Home > Technical > Intermittent Suspension Fault |
chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219 |
Nobody had this fault then? |
Tue Jul 26 2011 4:02pm |
awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355 |
you got either:
Tue Jul 26 2011 4:08pm |
chesterfield Member Since: 14 Jul 2011 Location: Chesterfield Posts: 123 |
If you are able to get the fault codes then it may shed some more specific light on the issue. Im guessing you will need a dealer to read the fault codes for you, or on some vehicles you can plug in an ODBII reader to access these codes yourself. I have one which connects to an in car pc system via bluetooth on another vehicle (350Z) and I can inspect for any fault codes myself - which can save a fortune on dealer costs.
Tue Jul 26 2011 4:37pm |
Stefan6666 Member Since: 21 Apr 2010 Location: Miami, Florida. Posts: 10 |
I experienced something similar and it got worse and I got the red suspension light(as someone posted before)
Thu Jul 28 2011 5:52pm |
dhenz70 Member Since: 08 Aug 2011 Location: gulf states Posts: 4 |
there is a small leak in the system |
Sat Aug 27 2011 8:31pm |
ELD70 Member Since: 20 Jan 2009 Location: UK Posts: 163 |
Normal suspects:
Sat Aug 27 2011 8:49pm |
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 |
When mine did this it was a fault in the loom. They can do resistance checks on the loom to identify the faulty part then replace the offending wire. Mechanics these days are becoming more like computer technicians |
Sat Aug 27 2011 8:59pm |
Ironically,
Sun Aug 28 2011 11:19am |
RRSSS Member Since: 01 May 2007 Location: Bahrain Posts: 172 |
Hi,
Sun Aug 28 2011 3:50pm |
You have a faulty earth on a light unit. |
Sun Aug 28 2011 7:05pm |
A month ago we encountered that problem, The dealer already replaced the drier kit as for the dtc C1A13-64,unfortunately suspension fault still there (access mode only,reset suspension when height is clear,etc),We found out that the air suspension was faulty.Good day |
Tue Aug 30 2011 7:59am |
gmilner Member Since: 19 Jul 2011 Location: Perth Posts: 26 |
I was getting exactly the same message regularly. Took it to the dealer and they replaced a suspension compressor. Problem solved. Greg Milner
Wed Aug 31 2011 1:32pm |
Faulty earth on light unit? |
Tue Sep 13 2011 10:16pm |
Are these comments directed at my problem (ie. for the images I put up)? Suffice to say, my problem is back, and the dealer seems clueless as to how to solve it |
Wed Sep 28 2011 9:00am |
